YA4926 meter boost button - Computers & Internet
Car got hot turned off won't start engian seems weak?
Felix, you probably have to get a friend to give you a boost,
if you get a boost run car for about an hour or so, take for a drive on highway, but do not turn off till home again, Battery should be charged by now,check voltage of battery with volt meter, should show 14.2-14.8 volts, this shows alternator OK.
. If it now still turns slow or in the morning, battery needs replaced if drops below 12 volts.
show your appreciation by pressing the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | 1999 Pontiac Grand Am GT
My car starts only when boosted
Measure the voltage across the car battery with a volt meter with the alternator running .. It needs to read 13.4 volts or higher to charge the battery.
Jul 08, 2017 | Dodge Cars & Trucks
100 meter distance of router and cp has no signal
The rule I follow when using a signal booster, is read the manual of my gateway and check the Max range of coverage, if it is 50 meters I'll place my signal extender at 25 - 30 meters away from the Router, if you go to the edge of coverage circle, your signal extender will suffer unstable signal, and would fail to boost the signal.
Jul 28, 2011 | 3Com OfficeConnect Router
Our westpoint home electric blanket, model 950, flashes 8 on one unit & can't be turned off. ELECTRIC BLANKET!!
Try pressing the power button and boost button at the same time. Then a C will flash and the setting you had it on before will show up. I think that was caused by pressing the boost button.
Dec 28, 2010 | Vacuums
Sons projects - Car doesnt crank over without a boost
have the battery charged andtested first. once a good power source is in there, take a volt meter and test your battery terminals for at least 13.5 volts. if not replace the alternator.
Jan 25, 2010 | 1992 Mercury Topaz
Our car for the past year has been randomly dieing and sometimes needs a boost and others it doesnt what could that be
By Boost do you mean battery jumpstart, could be intermittent electrical discharge fault,
Int light, Boot light, Alternator diode faulty,
Need to check charge rate with meter, should read about 13.8-14.2volts at idle with a good fully charged battery.
Dec 03, 2009 | 2002 Kia Rio
TRYING TO FIND THE LOUD BUTTON FOR MY KENWOOD KDC MP335 RADIO
Alright, the MP335 doesn't actually have a "loud" option, It does have Bass Boost settings, which you control by the B.BOOST button on the bottom row of buttons. If I remember correctly there should be 3 settings of bass boost. I hope this helped.
Nov 10, 2009 | Kenwood KDC-MP335 CD Player
Supercharger troubleshooting????
Check for a vacuum leak from the inlet and outlet hoses on the boost bypass valve and especially the boost solenoid.
Aug 03, 2009 | 1999 Pontiac Grand Prix
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
