Question about Symphonic WF803 DVD Player/VCR
How do i/can i record tv to a DVD ]
How do i/can i record tv to a DVD using a symphonic WF803 DVD/VCR combo
  • 77 Answers
If your using RCA cables (thats the red, white & yellow leads) you need run yellow RCA from the 'VIDEO (or) TV OUTPUT' at the back of your tv, to the 'VIDEO (or) TV INPUT' in the back of your DVD/VCR combo unit, & do the same with the red & white 'AUDIO' leads only run them from AUDIO OUTPUT(tv) to AUDIO INPUT(dvdrecorder). Now set the mode of the dvd recorder to TV IN or AUX IN. Now it should record whatever you see on the tv screen. But if your tv has an S VIDEO OUTPUT option, using an S VIDEO cable would be much easier & produces a better copy! Hope this helps!
Posted on Jun 19, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 65 Answers
You need a dvr recorder player
Can yoy help with a syponic player?
You should have a manual with instructions on the setup procedure. If not contact the support on their web page.
May 09, 2014 | Symphonic WF803 DVD Player/VCR
NEED CODE NUMBERS FOR UNIVERSAL REMOTE
Check these codes.
0456
[0458 0227] [0899 0236]
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD.
May 11, 2012 | Symphonic WF803 DVD Player/VCR
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found Here
Hope this helps
Mar 06, 2011 | Symphonic WF803 DVD Player/VCR
ok sounds like the settings have been changed like the region code if ur using compatable dvds-
Jul 16, 2008 | Symphonic WF803 DVD Player/VCR
Hooked up don't work
Hook the DVD Combo unit to the Video input of the TV. Not through your Dish Box. Then to View the DVD/VCR, switch the TV to the Video Input. Good Luck and have a great weekend
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Symphonic WF803 DVD Player/VCR
Dvd recorder won't record
I would try cleaning the laser first!
http://www.ehow.com/how_2036275_clean-lens-dvd.html
if that doesn't work try another brand of dvd's
if still doesn't work i would think the laser is weak.
Dec 18, 2007 | Symphonic WF803 DVD Player/VCR
How to hookup dvd.vcr to tv
first of all the the VCR has two connection from the tuner at the back one has out to tv the other has in from antenna you connect the wire from the cable company to the in from antenna.you connect another from the out to tv to the tuner connnection of your tv.and you are on.to connect the dvd to your tv.the tv has either at the front three female connector basic colors red white and yellow.the red and white is for audio in, left and right, and the yellow is for video in.the dvd has similar connections but they are output just connect them matching them color to color.there are some female connectors on the back of the dvd if you want to use surround sound.or play it through a reciever.good luck.
Mar 26, 2007 | Symphonic WF803 DVD Player/VCR
Symphonic WF803 DVD Player/VCR Logo
249 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
