Question about Bosch Drills
PBH 2100 No impact when hammering
2 Suggested Answers
  • 211 Answers
SOURCE: pbh 2200 re hammer action drill
hi
try to figure out how the switch operation mode works and put back together right.
bye savumihai71
Posted on Sep 16, 2009
Brushes for hammer drill PBH 1050 B2
Go to mfg web site for parts.
Sep 05, 2017 | Hammer Drills
Air opertes but locks up under load
Sounds like you might have a problem with the hammer (clutch) mechanism, these types of impacts are direct drive there a re no gears, so the hammer (clutch) mechanism must have the ability to splip after impacting to allow the air motor to turn. Disassemble and look for broken hammer pins, hammer dogs.
If you need a parts list you can go to CP.com, powertoolrepairohio.com or ereplacementparts.com
Feb 01, 2014 | Chicago Pneumatic 1/2" Air Impact Wrench
I have a ingersal rand 2141 3/4" impact the hammer frame had broken. It was replaced and
THE IR 2141 HAS A 2 HAMMERS, ON 1 SIDE IT IS FLAT AND ON THE OTHER IS HAS A BEVEL. THE 2 BEVELS HAVE TO FACE AWAY FROM EACH OTHER AND 180 DEGREES OPPOSED (1 UP AND 1 DOWN) IF NOT ORIENTED CORRECTLY IT WILL CAUSE THE MECHANISM TO LOCK. FOLLOW THIS LINK AND LOOK AT ITEM 15.
http://irtechpubs.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/04584009_ed1.PDF
May 01, 2013 | Air Tools & Compressors
Main wires to boschhammer drill pbh 240 re
They go to the switch where the two screw terminals are.
Mar 28, 2013 | Bosch Drills
Maintenance on a bosch pbh 2200 re sds, do i need to put oil or grease anywere in the drill?
The Bosch hammers all use a special grease for the hammering mechanisms. You should be able to buy a small tube similar to the size of a toothpaste tube, from a Bosch dealer or online. The part number is 1615430014. Here is what it looks like.
http://www.ereplacementparts.com/grease-tube-p-768150.html
Jul 16, 2011 | Garden
I have a BTD141 and it has been driving in screws perfectly. Am on 2nd battery charge. It has lost the hammer/impact feature. It only occurs if you push so hard you bend the screw. No long impacts. I...
could be the anvil stuck on the hammer mechanism, try locking a bit in a vise and impacting. also could be wear on the edges allowing the 2 to slide past each other
Jan 11, 2011 | Makita 18 Volt Hammer Drill Impact Driver...
I can't remove the chuck bit from my hammer drill PBH 2000 re
This is normally easy procedure, just press chuck inward and turn clockwise, then retrieve.
This is same way as you will insert/remove your drill from the chuck.
If this method is unsuccessfull, plese rotate knob (close to chuck) anticlockwise till you go to position between chiseling and driling, as this is not lockable position, you need to hold knob in one hand and manipulate chuck with other hand.
This method is described in more detail in manual which comes with hammer-drill.
Hope this solve your problem, this is excellent tool and I always love to use it. Will handle drill up to 20mm in concrete and not even much vibration.
Aug 12, 2010 | Bosch Drills
Hammer action power there but weak
It is hard to understand what you are asking, however I have found that with the SDS drills one does NOT want to crowd them but just let the tool work with light pressure...
Feb 07, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Pbh 2200 re hammer action drill
hi
bye savumihai71
Oct 13, 2008 | Drills
Drills Logo
35 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
