Question about Vantec Nexstar Computers & Internet
Nexstar 3 external 3.5 hard drive enclosure esata & usb2.0 interface
fire sine
  • 382 Answers
SOURCE: Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Posted on Oct 22, 2007
SOURCE: Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
Posted on Sep 11, 2008
wuntwowun
SOURCE: Computer not detecting NexStar 3 USB 2.0 External hard drive
I'm not a computer expert so I won't use too much tech language but after months of dissapointment, I finally got my NexStar 3 to work and it was actually easy!
At first I thought it was a driver problem so I tried to find a driver on line or in the disc provided (it wasn't neccessary as I run windows XP).
Then I actually opened the disc provided and found the PDF manual and opened that for a read (maybe the answer was in there?) Yep!! It has the answer you are looking for. Part of this manual 5.2 describes that "a partition is required" if the hard drive does not appear under My Computer.
To do this you:
Right click on your "My Computer" icon and choose "Manage",
Under "Storage" on the LEFT pane, select "Disc Management",
Find the drive (mine was around 300GB so I knew it was the one) at the bottom Left and "Initialize" the disc by clicking on "not initialized",
Then in the bottom RIGHT Pane, where the status bar is, Right click and choose New Partition,
Follow the directions from the Wizard. (Recommended partition type is "Primary" and file type "NTFS".
When this is done you should see your drive under My Computer.
NOTE: This formatted around 23GB on the newly created "E" drive I selected.
After this, by Right clicking the other unallocated area of the drive I went on to format the rest of the drive as a "F" drive which contains the other 256GB.
Hope this helps!
Keith in South Australia.
Posted on Sep 20, 2008
  • 75 Answers
SOURCE: I have a NexStar 3 external hard drive that is not
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Posted on Mar 30, 2010
lock123
  • 6831 Answers
SOURCE: I have a Nexstar 3 external 3.5 hard drive and it
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
CAN I USE MY HARD DISC WITH USB CONNECTION
Yes, you can. You'll need a little more hardware however. You can find "hard drive enclosures" at many computer stores, ebay and electronics stores. They look like these. In order to make this work, you need to determine the physical size and interface of the Samsung hard drive first. Most notebook drives are 2.5" and most desktop drives are 3.5" types (regardless of capacity). You'll need to find an enclosure for the drive size and interface type.
The Samsung drive is likely to be either and IDE type with a SATA (serial) or PATA (parallel) interface. Pictures of SATA cables are here, and PATA cables are here. You would select the enclosure depending on 2.5" or 3.5" size and SATA or PATA interface type. Lastly, would be to choose either a USB connection between the computer and enclosure, or an ESATA type. ESATA simply means External SATA. If your computer offers an ESATA jack on the front or rear panel, you might consider using it as it is much faster than USB. If you do not have an ESATA jack, stick with the USB type. All but the most oldest computers support USB 2.0 standard speeds, newer computers have a faster USB 3.0 speed (5Gbit/S) standard, but this hardware is fully backward compatible to the USB 2.0 & USB 1 speed (480Mbi/S) and hardware standards. If your computer has the original USB 1.x standrad speeds, you might consider purchasing a USB 2.0 or 3.0 expansion card as the USB 1.x standard is very slow (just 12 Mbit/S). Check these links for pictures of ESATA, USB 2.0 and USB 3.0 If you look closely, you can see the slight differences. USB 1.0 and USB 2.0 look identical.
Some enclosures will require / include a power adapter for the drive. Make sure you get what is required to get the drive to spin up properly. After your computer is up and running, connect the external drive to the USB jack and let the computer install drivers as needed; then use it as any other thumb drive etc. ESATA however may be different. In any case, follow the instructions included with the enclosure you purchased.
After copying good data, you might be able to format and scan the Samsung drive and map out the errant portions. Even still, I would not use the drive for important information or day to day uses. If you do, be sure to maintain frequent backups.
May 23, 2012 | Computers & Internet
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Help
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Oct 04, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Computers & Internet Logo
74 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
Piyal Perera
Piyal Perera
shahid_ptv
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
