Question about Vtech DECT 6.0 Digital Cordless Phone
How to delete names - Vtech DECT 6.0 Digital Cordless Phone
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Since you declined to specify the model of your VTech DECT 6.0 system, please enter it into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Posted on May 16, 2014
How do u delete a name from messenger list? Do not want to block or unfriend just do not want names showing
just click on there name and it should let you delete.
that's right click on the name.
if not just high light the name and see if it will let you delete. go into your messenger list and try the above.
when you highlight the name and you right click on it,it might let you delete.
mind you if you do delete them they will be removed from your messenger..are you sure you want to do that because you are saying you just don't want to see there names.then you would want to hide there names.not delete.
Nov 06, 2016 | Computers & Internet
How to shut off Bluetooth in my gmc Yukon
Using the
Delete
Command
1. Press and hold
b
g
for
two seconds.
2. Say
Delete.
3. Say the name tag you want to
delete.
Using the
Delete All Name Tags
Command
This command deletes all stored
name tags in the Hands
Free
Calling Directory and the OnStar
Turn
by
Turn Destinations Directory,
if equipped.
To delete all name tags:
1. Press and hold
b
g
for
two seconds.
2. Say
Delete all name tags.
Listing Stored Numbers
The list command will list all stored
numbers and name tags.
Using the
List
Command
1. Press and hold
b
g
for
two seconds.
2. Say
Directory.
3. Say
Hands
Free Calling.
4. Say
List
Dec 23, 2014 | GMC Yukon Cars & Trucks
Delete name ranges
It's a bit counter-intuitive...
Go Insert / Name / Define and the Define Name Dialog box will open & display the existing Range Names.
Select a Range Name to delete and hit the delete button.
Repeat as required.
Hit OK to finish.
Done.
Jan 09, 2014 | Microsoft Excel for PC
How do I delete a contact from fax settings
Deleting a Registered NameThis section describes how to delete a name.
  1. Press [System Settings].
  2. [Administrator Tools>.
  3. Press [Address Book Management].
  4. Press [Delete].
  5. Select the name you want to delete.
    Press the name key, or enter the registered number using the number keys.
  6. Press [OK].
  7. Press [Exit].
  8. Press the [User Tools/Counter] key.
Sep 16, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
Mhow to delete someone on your messenger list
you may wanna try this:
How to Delete a Contact Text Size: small A normal A large A ID: DOC263
To delete someone from your Messenger List:
  1. Click the contact's name while pressing the Control key to highlight the contact. (You can also right-click on the contact's name.)
  2. Select Delete.
  3. Click the Delete confirmation.
To delete someone using the Contacts menu:
  1. Click the contact's name in your Messenger List.
  2. Click the Contacts menu and select Delete.
if this helps pls rate me thanks
Mar 22, 2011 | Yahoo Messenger
Phone book names are not always appearing when receiving calls
Check may be you have saved names on phone aswell as sim.
So delete some name in "sim" memory and check.
  • On the Home screen, click Address Book.
  • Open the menu and select SIM Phone Book.
  • To delete an entry, highlight it, open the menu, and select Delete.
  • When the Delete Phone Book Entry? message box appears, click Delete.
Nov 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
Remove abbyy finereader
Go to start, run and type in regedit....Be very careful while doing this...Click edit find and type in the name finereader and delete it. Hit F3 and when it finds the name again delete it. Make sure you only delete that name. Go all the way and delete that name intill it says it is finished searching the registry. Then search the computer for the name and delete it. I promise it will be gone....Darren
Oct 10, 2009 | ABBYY Software House FineReader 5.0 Pro...
How do I delete the names in my contacts list?
just delete the name and save it blank dont put anything in it and save it try that.
Jul 08, 2009 | LG Xenon GR500 Cell Phone
Can't delete some data already installed in Kingston pendrive?
What type of files are they (be more generic if files are personal and/or name the extension names of each files that cannot be deleted)
Solution:
- Try changing the name of the files and then deleting them
- Is your USB Password Protected ~ this may stop you from deleting those files (try deleting the Security on your USB)
- System Deletion Performance may be slow and.or unknown Deletion Command
Hope I helped
- donman92
Jun 01, 2009 | Computers & Internet
How do I delete a name from Leapster? I bought it used.
Question How do I delete or change a player name on Leapster™ cartridges? trnsp.gif Answer It is possible to remove a player once you have added three player names to the cartridge. If there is a name on the cartridge that you want to remove, take these steps.
1- Add new players until there are three players on the cartridge.
2- Once you have three players on the cartridge, an "X" will appear below each player's name.
3- Touch the "X", then touch the name of the player you want to delete. Touch "Yes" to delete the name. Then add a new name, or touch OK twice to go back to the sign-in screen without adding a name. Two names will always remain on the cartridge.
Dec 23, 2008 | LeapFrog LeapSter L-Max Console
Vtech DECT 6.0 Digital Cordless Phone Logo
12 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
