Question about Project IGI IM GOING IN
INSTALL ERROR when i start the game it says fatal error cd not found
When i Start the game.Then it comes an error.SAYS(Fatal error: Couldn't flip Directx message: Unknown error)
The problem with your game is that the DirectX component compatible with the game is not installed properly or there are some files missing in the DirectX directory.Try re-installing the DirectX.
Thank You
Dec 26, 2012 | Project IGI IM GOING IN
What is causing igi starting error?
There are so many reasons why the fatal exception error has occurred. First, your video card maybe has below specs and need to upgrade. Second, maybe you didn't install a direct x in your computer that's why games didn't run successfully. Last, some files are corrupt so the game will not run properly. Solutions:
First, upgrade your video card to a higher spec.
Second, try to install a direct x in your computer. This is the link to download DirectX
Third, try to uninstall the game and reinstall it again.
Aug 17, 2011 | Computers & Internet
I had download destruction derby 2 and it is in image format , so i mount it to virtual drive h and install it but after installation when i opened it , it is giving fatal error-destruction derby 2 CD...
Are you sure that the game contains only one CD.......Some games require 2 image files to be mounted on two Virtual Drives..........OR Copy Crack(if any) found on the image to the game directory..
Jun 24, 2011 | Racing Destruction Derby 2 for Windows
Fix the fatal error in my warcraft 3 frozen throne
This application has encounter a critical error:
FATAL ERROR!
Program: F:\games\lan games\warcraft 1.24.1.6374\war3.exe Exception 0xC0000005(ACCESS_VIOLATION) at 001B:15019B9E
The instruction at '0x15019B9E' referenced at '0x57746E65' Ther memory could not be 'read'
Press OK to terminate application.
Then:
Frozen Throne was unable to locate your CD-ROM drive. Please make sure your Frozen Throne disc is in your CD-ROM drive, then click on 'Retry'.
Oct 22, 2009 | Blizzard Entertainment WarCraft III: The...
GTA 4 FATAL ERROR: RESC10
If you are trying to run it on a PS3 console, Try to upgrade you'r PS3 console
Aug 03, 2009 | Rockstar Games Grand Theft Auto™ IV for...
D3DERR_NOTAVAILABLE
its direct 3d driver: you need to reinstall the last version of directx, or perhaps your videocard driver before
Nov 21, 2008 | Microsoft Windows XP Professional With...
Problem
You may have to update Directx to V9 for XP, also check to make sure that the Acer meets the minimum system requirements that the game needs to run (will be found on the box or CD sleeve).
Jul 15, 2008 | Acer Aspire 5050-3242 Notebook
Navigation fatal error Error 1706
yes..I saw that..need teh model number of the actual gps you are using, please..
Mar 09, 2008 | GPS
Project IGI IM GOING IN Logo
Top Project Video Game Consoles & Games Experts
James Wishart
Are you a Project Video Game Console and Game Expert? Answer questions, earn points and help others
