Question about Gaggia Syncrony Espresso Machine
Brew unit block - Gaggia Syncrony Espresso Machine
3 Suggested Answers
  • 109 Answers
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Posted on Feb 22, 2010
  • 21 Answers
SOURCE: The machine is showing the brew unit is blocked bu...
Does the brew unit try to move at all? You can listen for the motor, or open the door panel and defeat the safety interlock while it's operating. (Be careful not to put a finger in there.) Then you can observe where the brew unit is getting stuck.
Posted on Aug 14, 2010
"brew unit block" medium cup in service mode dont work only the small cup works
When the alert came up- Brew unit blocked- this is before you started taking things apart, A, were you able to remove brew unit, Yes or No?
B, after turning power on and then off, Did the machine try to reset brew unit to home position Yes or no?
If Yes were you able to remove brew unit?
Aug 18, 2014 | Miele CVA615 Espresso Machine
Brew Unit Blocked
open the door and see small screw in the middle of the brew unit. Take it off with small screwdrive and pull out the brew unit.Then put the small thing (something like a pipe) to the brew unit with the small screw. Then without brew unit in the machine press the switch inside the machine where stayin the brew unit and the switch witch is stayin the top of door .Switch on the machine and wait while self test is making,then put the brew unit in the machine and that it.Enjoy!
If you have any question -ask me.
Nov 25, 2013 | Saeco Royal Professional Espresso Machine
Brew unit blocked message The brew unit removed and switches jumped, motor turns message still blocked brew unit . what could it be and ways to tests.
I had the same issue. Very difficult to fix. You must remove brew unit and reset the machine while apart. You must trick the machine to think brew unit is installed and door closed. Look at door and brew unit and use screwdriver or butter knife to engage machine and run through cycle to reset.
Jul 09, 2011 | Starbucks Saeco Italia Digital Barista...
The machine is showing the brew unit is blocked but we have taken it out and cleaned it but this makes no difference.
May 19, 2010 | Gaggia Syncrony Compact Digital Espresso...
Syncrony Compact Digital unit- Used well for 5 yrs without incident. Currently, after bean grinding and tamping stages, a strange, non metallic rumbling/grinding sound occurs just before the...
First clean the screen and tube on the brew unit, then lube the guides/gear grooves on the brew unit, also lube the o-ring(big red one). Then that should take care of it. You can also try backwashing/degreasing the brew unit if the machine has a preground chute.
Feb 07, 2010 | Gaggia Syncrony Compact Digital Espresso...
Jan 03, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Brew unit and waste unit in place, brew unit is blocked
For Brew Unit Block:
  • Turn Off
  • Hold small coffee & hot wate atthe same time
  • Turn on with light (numbers sill appear)
  • Hold medium coffee util arm returns to normal position
May 27, 2009 | Miele CVA615 Espresso Machine
Brew Unit Blocked
If when you first turn it on and it does not go through the self test and then says brew unit blocked. You may have a wire loose on the board, (common) The motor that drives the unit may be bad. In either case you should have a professional look at it. Google saeco repair and have choose an authorized saeco repar center.
Sep 03, 2007 | Saeco 762111651808 Espresso Machine
Gaggia Syncrony Espresso Machine Logo
50 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
