Question about Garden
Karcher 102b gun leaking
My Karcher 102b pressure washer is leaking and the water is mainly coming out from the yelow 'switch' at the bottom of the handle. Do I need a new gun?
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
Posted on Jul 25, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
SOURCE: karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Posted on Jun 26, 2012
Its leaking water
Take it out of case
Connect to hose. Turn on tap & see were the leek is.
Jun 14, 2015 | Karcher 16016080 K2 26 1600 PSI Electric...
My karcher pressure washer 520 M is leaking water from the hand gun
You should watch the video on this blog. This is a very common problem, because the original gun/wand on many pressure washers is the same! However, Prism Teachings observed something that you should know about its design: http://electricreplacementgun.blogspot.com/
May 22, 2012 | Karcher K2.26 Electric Power Washer
Water leaking out of bottom of washer
It sounds like water was left in the pump and i froze over the winter and cracked the pump housing. You can try taking the gun hose off and blow compressed air where the hose hooks on to blow waterwater out of the pump and dry the bottom. Then put some apoxy on the crack to seal it.
Mar 18, 2011 | Karcher 2500 PSI Pressure Washer
I have a Karcher 110 pressure washer and when switched on to jet wash the water is coming out of the handle and just trickling out of the jet nozzle please can you help. Thankyou Brian Hills
Which part of the handle is water leaking from? It could be that the hose connection into the gun is not fitted properly. Otherwise it could be that you just need to replace the handle.
Feb 28, 2011 | Garden
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Karcher Model K 2.40, water is leaking from the gun at yellow trigger.
You are going to have to purchase a new trigger gun, they don't offer any parts for replacement on the inside of this trigger gun. See this link to purchase a new one.
Oct 08, 2010 | Karcher FactoryReconditioned K240R 1400...
Water pouring out from bottom of machine leading to loss of pressure
You will need to remove the main cover and see where the leak is coming from. Could well be either the water inlet or the main pump seals .
May 20, 2010 | Karcher PSI Electric Pressure Washer
Pressure washer lacks pressure initially?
Dear allbusiness9,
This problem is most probably due to a faulty Spill Valve( also called Control Valve). When the gun is released the spill valve is compressed and it either closes a micro switch or just opens from the bottom and keeps the water circulating. All spill valves keep the water circulating from the bottom part. Now when the gun is pulled (opened)...the spill valve extends and closes the bottom part, and thus water goes out of the nozzel. When you work with no nozzel, there is enough water flow to close the bottom part of the spill valve. So when the nozzel is placed back there is no chance that the bottom part leaks water. When the gun is started with the nozzel....the bottom part of a FAULTY spill valve,..will colapse and pressure drops. So to fix the fault you must change the Spill Valve. In some occasions, I also found that suction valves give this problem. A faulty sucktion valve will colapse under high pressure, and lets water pass the other way round.
But in my opinion and experience, your problem is in the Spill Valve.
Regards,
Fulltech.
Apr 23, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
