Question about Fellowes Manufacturing Powershred SB-97CS Shredder
SB-97Cs Full red light stays on
We have a SB-97Cs. The red light stays and will only shredd by pushing reverse and then forward and it will only shredd 1/4 of page before red light comes on again. I have checked the "eyes" that they are clean. what could be wrong? I suspect the "eyes" are shot? How do we fix it? The eyes are based on a diode send and receive function like a tv remote. Can we buy near Infarred, diode send receive?
  • 328 Answers
You can order from Fellowes or a dealer like myself. Maybe the unit is all jammed up with shreds in the housing. Try taking the top off and cleaning it throughly. Be careful with the short ribbon cabl.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 22, 2009
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
Parts for fellows sb-97cs
Check eBay for parts or Craigslist for a shredder you can cannibalize. Sometimes Fellowes can give you the part number which can help you search.
Jul 03, 2014 | Fellowes Manufacturing Powershred SB-97CS...
Shredder stops - red light off
Some shredders are great for thicker paper. If you put a thicker piece of card through, it should activate the switch located in the middle of the shred blades. The paper might be too light to push it forward. Also, if you click the feed catch beyond it's operating position, this can also stop the shredder with no lights.
Jan 25, 2014 | Intimus 280 Shredder
New Bright, F-150, Red Thunder 4X4: Truck goes into "static" mode when forward or reverse is pushed on remote. In other words, truck starts up when turned on, steering, horn and lock work fine,...
Get new battery, I have 4 batteries, all will turn it on, get horn lights, sound. 2 do the exact same thing yours is doing, 1 runs about 5 min then starts into your problem, 1 is good and will run for about 20 mins.
Aug 27, 2011 | New Bright Ford F150 Rc
My son put a 25 page document in this shredder and bound her up better than any shredder jam I've EVER seen. What's the best way to clear this mess when the shredder can't overpower the jam? I'll pull...
There are various ways to clear the mess if you have patience and the time to work the jam. 1. Unplug the shredder and use a flat-head screw driver to dig as much out as you can, then plug it back in and flip the switch from forward to reverse a few times and then keep repeating the process until jam is cleared. 2. Use tweezers to remove paper from critical connection teeth and the try it again.
Nov 16, 2010 | Fellowes Manufacturing Powershred SB-97CS...
One of the gears in my sb-97cs has broken. The motor runs but the broken gear prevents the teeth from rotating and pulling paper into shred. I have spoken with people at Fellowes on the phone and they have...
I have the same problem with a stripped gear, to remove the top i found it best to place the shredder on its back, then with a pozi screw driver there are 5 screws securing the top in place, these are inside the shredder above the paper bin, 1 in each corner and 1 in the centre.
Hope this helps.
Jan 14, 2010 | Fellowes Manufacturing Powershred SB-97CS...
HSM AMA 125HS-6 Starts to shreed and abuptly stops. Red light comes on next to a circl symbol.
Thickness of papers is too much. Feed only 1-2 pages at a time.
To clear, pull paper back out. Run reverse, then forward, then feed 1 page at a time using a clean edge.
Sep 13, 2009 | Office Equipment & Supplies
The bin is full light remains on even though it's empty. How to I get it to work correctly?
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Dec 24, 2008 | Fellowes Manufacturing Powershred SB-97CS...
Fellowes Manufacturing Powershred SB-97CS Shredder Logo
384 people viewed this question
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
Tony
Tony
Level 1 Expert
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
