Question about Danze Plumbing
Danze melrose shower faucet
Location of pressure balancing valve
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
manhandy
  • 146 Answers
SOURCE: Danze pressure balance single handle shower faucet
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Posted on Jun 26, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
SOURCE: Speakman shower faucet washer replacement
Keep unscrewing, to the left. Past the point that would normally be the full "on" position for the valve. I've just removed my Speakman Kent shower stem, and because it is damaged where the washer attaches, will have to replace it (both of them).
Posted on Jan 10, 2010
New danze cartridge no water
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
May 18, 2014 | Danze Home
Leaky danze shower faucet
you need to go to lowes or your nearest plumbing supply store and get a new cartridge and replace...you may also just be able to replace springs and seats if its like a delta...i believe danze is made by delta...ask them for help and they will advise you on parts...good luck...remember to shut water off to home before doing this repair...
Oct 17, 2012 | Danze D500511BN Brushed Nickel Melrose??...
I recentlly had a Danze model # D11200BT installed in my tub shower. The problem is every time you turn the water off there is a banging sound that comes out of the valve it self. The sa me thing happens...
You have what is called water hammer effect going on the water pressure is to high this can cause problems with all you plumbing fixtures. You need to have a water hammer arestor install or put a main line pressure reducing valve in.
May 29, 2011 | Danze Plumbing
I have a Danze D112000BT Single Control Pressure Balance Mixing Valve with Screwdriver Stops that was installed in 07, it been working fine then last week it all of a sudden became really stiff to turn...
Danze cartridges are known to have problems after time with hard water. If you call Danze at 1-888-328-2383 USA
Canada: 1-800-487-8372
They have a lifetime warranty of defects, and will replace the cartridge for that valve for free. It will actually be best to have a plumber do it because taking the cartridges out can be simple, putting them back in and tightening it up the way it should be can be tricky. It is nice that you have the valve with the screwdriver stops. That allows you to remove the cartridge without having to turn the water off to the entire house. Simple turn each stop to turn the water off, remove cartridge, put new cartridge in.
May 01, 2011 | Danze & Single Handle Tub And Shower...
Loud knocking when washing machine turns on (solenoid)
this is caused by plumber not strapping pipes properly and probably not having air chambers install for knock...not much you can do unless you can get to pipe and strap...or spray with spray foam to set and secure pipes...
Mar 28, 2011 | Danze D500511BN Brushed Nickel Melrose??...
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Danze pressure balance single handle shower faucet (D500558BN) pipes vibrate when adjusting hot and cold water.
Jun 10, 2009 | Danze D500558BN Parma Shower w/ 4"...
Shower valve leaking
here is the link to the pdf file http://www.plumbersurplus.com/pdf/07606.pdf
If you cant get directly to it from the above link, go to plumbersurplus.com/prod/danze-D51001BNT then click on "documents"
Apr 04, 2009 | Danze D510011BNT Brushed Nickel Melrose??...
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Nov 09, 2008 | Danze D500558T Parma Shower w/ 4"...
Plumbing Logo
21 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
