Question about Refrigerators
Frigidaire lfus2613lfo beeping
Keeps beeping on the second, no light on temp control Already tried unplugging for a few minutes with door both open and closed, neither has worked
  • Amenaza Omar
    Amenaza Omar Apr 22, 2014
    thatnks for the help, seems like not only is it beeping, butit is also not cooling fridge or freezer. at this point I would think the problem would not be ice maker, since fridge is jot cooling
  • Refrigerators Master
  • 884 Answers
Check the condenser is clean and the fan running. Check for compressor hummimg
Posted on Apr 22, 2014
5 Suggested Answers
SOURCE: Lights flashing on front panel and trap door for
With your ice maker not working properly, you might be wondering the reason behind the malfunctioning of your ice maker. Several factors could be involved in case your ice maker is not making any ice at all. It might be caused due to a defect in the water supply line. It could be possible that the water valve isn't getting any water. Check the water line at the back of the freezer for any blockage. Look for the water shut-off valve placed behind the refrigerator or under the sink and turn it off.
Next step would be to unscrew the copper line located at the back of the refrigerator. Now place the copper line in a bucket and turn on the valve to check if pressurized water comes out. The problem could also be linked to a defective tap valve. You could have it replaced. Since, freezer temperature can also be responsible for ice maker malfunctioning, make sure the freezer is not too warm.
Take care.
Posted on Sep 25, 2010
  • 2468 Answers
SOURCE: I have a Frigidaire freezer
you also need to replace the door dispenser board too,if not done already on this unit,as this board has the "piezo" signaling device your hearing "Beep", and this board sends all refrigerator/freezer signals to your main-board in the lower rear area to tell the unit how to operate the electronics/this small board in the door is JUST as IMPORTANT as the motherboard/mainboard in the back,because both boards communicate with each other to keep the unit operating as designed
Posted on Nov 24, 2010
heatman101
  • 43501 Answers
SOURCE: freezer workig fridge not cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 06, 2011
br27
  • 39 Answers
SOURCE: Frigidaire model ffus2673ls2: Constant beeping
it is a sensor going bad.
Posted on Oct 17, 2013
Testimonial: "Need for info."
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Why dose it keep beeping ?
Jun 20, 2015 | Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 03, 2015 | Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Apr 25, 2015 | Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
What causes my Kenmore to buzz when dispenser door is closed?
Sep 14, 2014 | Kenmore Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
The garage door is closed and wont open, it beeps and all the LED's light up. there is no obstructions. I think that it keeps to try and shut but already is. Its a securalift GDO - 7 V1
Tries changes batteries in the remote,unplug the main operation motor,replug it,see if it reset it self.This a temp.fix,call the mamfucture for repair or replacement.
Oct 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
