Question about NEC 80573 Corded Phone
How do I program caller ID to work on lines 4 & 5
  • 3 Answers
Caller id must be set up through your phone provider, (beware they normally charge a monthly fee for the privilege.
Thanks )
Posted on Jun 19, 2009
4 Suggested Answers
  • 65 Answers
SOURCE: portrait caller id
Knowing what kind of phone you have will help us find an answer.
Posted on Feb 09, 2008
TeleFurb
  • 16 Answers
SOURCE: No Caller ID
Check to see if all of the expansion cards have a numer followed by "ec" like 308ec 206ec 400ec, if not that card is not capable of called id.
Posted on Aug 25, 2009
cnavarro
  • 2460 Answers
SOURCE: I have a panasonic kx
Hard to say. So, go to the cabinet and swap the connections between line 1 and line 2. If the CID still comes in on line 2 and not 1, then it's hardware or programming. If it doesn't come in on 2, then it's a telco issue. Since you checked programming, it would only leave hardware. The 82493 card plugs into a slot on the main board.
Carl
Posted on Mar 16, 2011
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
I have a panasonic kx ta824 system with caller id. Caller id works fine on lines 2 & 3, but no longer works on line 1. This is a new problem after 3 years of it working properly. I checked the...
Carl
Mar 15, 2011 | Panasonic KX-TA824PK Phone
How do I set up a phone to display caller id? It displays on other phones in the office but not on mine.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
May 03, 2010 | NorStar T7316E Telephone
StarTalk Flash is 1.7.00 + caller ID
The Star Talk Flash is a voice mail prduct. The caller ID feature is a phone system feature. If your system is a norstar CICS or a MICS the caller ID will work only if you have the caller ID capable central office circuit packs installed. Look on the card and see if the label has "CLID". If it dose there is also additional programming required for each set under.... terminals &sets/telco features/featue assignments/show line/caller ID...set:Y. You also have to program (under sets) /telco features/caller ID: Y.
Hope this helps.
Mar 24, 2010 | NorStar M7310 Corded Phone
How do you set up caller ID on a Norstar M7208 phone with 4 lines?
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
Jul 23, 2009 | NorStar M7208 Corded Phone
No Caller ID on display
To set up call id you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
that should do it providing you have caller id service though your local telco provider.
Mar 25, 2009 | NorStar T7316E Corded Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Portrait caller id
Feb 08, 2008 | Lands Phones
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Oct 23, 2007 | GE 28111 Cordless Phone
Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Aug 20, 2007 | Avaya Definity 6408D Corded Phone
NEC 80573 Corded Phone Logo
160 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
