Maytag dryer mdc1305aaw
Empty Water indicator is on but water caontai9ner is emptied.
  • siatoz
    siatoz Apr 26, 2014
    Well it appears that I may have worked it out by myself. After not being able to locate any assistance from good old google, I decided to take matters into my own hands. What am interesting experience. I now know more about how the mechanics of this Maytag dryer work. After determining that the only way to get to any of the rear water tank was to remove the drum, I set about pulling the machine apart. After removing the drum, I found a switch that is activated by a float in the rear water container. With multimeter in hand I tested the switch only to find that it was still in working order. Hmmm. Time to put it back together and call the professionals. 2 hours later it was back together and I must say substantially cleaner. Even with all the filters in these things, the amout of fluff that gets through and accumulates inside is incredible. Just out of curiosity, I decided to turn it on and see if I had somehow managed to scare this thing in to working. Guess what, I did. Next was the running test, a load of tea towels went in after the washing load was finished. The dryer performed for some time and then out of nowhere, the Empty Water light started flashing. Insert expletive here! Well after a good nights sleep, I decided to have another look. The machine started to work but asfter a minute it started flashing the light again as I touched the door the light went off and the machine kicked in again. The long and the short of it is that after a few gentle tests, it appears that a switch located at the top of the door cavity is a double, meaning that it determines if the door is closed tightly or not. If the door is even a few millimeters out, the empty water light flashes. A bit misleading and not in the owners manual however, as my wife informed me afterwoods, normally the empty water light is on solid, not flashing! With all the opening and closing these doors do, it is no wonder that after a while the switch may become a bit worn out. Well, I hope this helps someone else.
    Sergeant:
  • 419 Answers
Try follow the instruction on original manual or at web site indicated below
http://www.manualslib.com/manual/100392/Maytag-Mdc1305aaw.html?page=14#manual
Important: Always switch off and remove the plug from the electricity supply before cleaning the condenser. To maintain the efficiency of the dryer regularly check that the condenser is clean. To remove the condenser 1. Remove the kickplate (see page 13). 2. Turn the two locking levers anti-clockwise and pull out the condenser. 3. Pull out the condenser unit. 4. Gently remove any dust or lint with a cloth, then wash the unit by holding it under a running tap turning it so that water flows between the plates, to remove any dust or lint. 5. Refit the condenser ensuring it is in the correct way (as indicated by the arrow) and pushed firmly into place. Lock the two levers by turning them clockwise. 6. Refit the kickplate.
plug back the machine
Posted on Feb 15, 2015
The water empty indicator keeps flashing indicating we need to empty it BUT it is empty !!!!Now the aircon won't work We emptied a lot of water however now it keeps beeping a warning,the compressor shuts...
I am NOT aquainted with the Maytag Portable AC..... But There has to been a sensor that tells the unit that the water bin is full...... If there is any moisture on the sensor and touching a ground probe then even though the bin is empty the sensor is still making a connection to ground. If you can trace out the wire that goes to the sensor you can unplug it from the board till it dries out or you replace it..... Only if you do make sure you empty the bin often or you will have water every where because the unit won't shut off if the water bin is full..... Hope this helps
Feb 05, 2011 | Maytag Portable Air Conditioner M6P09S2A
Water in my dryer when it is empty
Sounds like your problem might be the washer not spinning the wash enough not the dryer unless it is not heating properly.
Aug 23, 2017 | Maytag Dryers
I have hotpoint consdenser dryer model ctd00p - not drying clothe
if the water tank is empty you probably need a new thermostats .
Feb 11, 2010 | Dryers
Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Dec 31, 2009 | Hoover Dryers
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
Says 'empty water' but empty - leave to cool and works again for 30 minutes?
Might be a faulty water level sensor or it could be the sensor has some fabric softener on it.
May 19, 2009 | Dryers
Where is the water unit?
Its at the bttom, near the floor, you have to remove the front plate and there is a plastic container that slides out of the bottom
May 07, 2009 | Candy CDC266 Dryer
Empty water button staying on
Remove lower left filter from dryer, and wash it out under running water. Reach inside the compartment and clean any fluff and gunge you can find there.
Get a plastic bag tie or similar, and feel for and locate a small hole at the rear of compartment, poke it clear with bag tie.
If you are certain that the element and stats are o/k , and it still does not heat and the light stays on, then that indicates that the float switch is stuck or is faulty.
To access this involves stripping the dryer down, not an easy job.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Bosch Axxis WTA 4107 Electric Dryer
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
