Question about RCA Audio Players & Recorders
My clock won't power on.
RCA 2012
Radio dose not work
It can be issue with radio fuse or wiring issue of radio.
First test the radio fuse.If its blown out,then replace it.If the fuse i checked ok,then its radio wiring issue.Test the voltage.
Check out few help links provided below,related to car radio problems:---Click the link below:---
Radio Controlling Fuse Location? http://howtobyme.blogspot.in/2012/05/2003-lincoln-aviator-radio-controlling.html
No clock, radio, gps, climate control After Battery Cross Jumped? http://whatisbyme.blogspot.in/2012/05/2006-lexus-ls430-no-clock-radio-gps.html----------
XM satellite radio interface kit Connection? http://technoanswers.blogspot.in/2012/04/toyota-avalon-toyota-xm-satelite-radio.html
Radio Power Antenna wiring diagram? http://technoanswers.blogspot.in/2012/02/radio-power-antenna-wiring-diagram-for.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
2006 Ford Expedition radio not powering ON? http://technoanswers.blogspot.com/2012/01/2006-ford-expedition-radio-not-powering.html
How to reset Radio code after car battery is died? http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
These details will help.
Thanks.
Jul 21, 2012 | 1990 Audi V8 Quattro
After a power outage, my rca alarm clock (model RP5435A) is frozen at one time, and no buttons work. Advice?
Hello
Take out the memory battery that have been installed in it. Just wait for 3 minutes. Reinstall batteries, and set the time according to its user manual says. OK.
Aug 29, 2011 | RCA Radio Alarm Clock
What battery does it use?
RCA Alarm clocks use a standard 9-volt battery as a backup-power source.
Aug 26, 2011 | RCA RP4897 Clock Radio
My clock is constantly blinking and won't go on the right time. I unplugged it and plugged it again, it just keeps blinking.
Hello
Check the bckup batteries in the clock first. If they are weak, backup function will not work properly, and the display will blink after a mains power failure.
Auto Clock Set
You do not have to set the clock time as a
built-in automatic time set system is
equipped in this clock powered by 3V (2
X AA batteries, included). All you have to
do is to plug this clock for power and
current time will be shown automatically.
However, the batteries can also be
exhausted and we recommend that you
replace the batteries every 2-3 years
Before You Plug for Power
1. Setting Time Zone
You may slide the TIME ZONE selector at
the back of the unit to Eastern (EST),
Central (CST), Mountain (MST) or Pacific
(PST) (refer to the maps on the right).
2. Daylight Saving
You can slide the DST switch at the back
of the unit to turn on/ off in areas
observing/ not observing such time
change.
WARNING: Please avoid playing with
these buttons after entering the
Clock/Alarm set mode.
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
time. The time decrements or increments
will follow by a faster rate when you press
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
OK.
Aug 12, 2011 | RCA RP5430 Clock Radio
We had a momentary power failure (breaker tripped). Once power was restored, the radio works but the clock does not. No display at all. Any idea?
It sounds like the outage caused a surge in power and damaged your clock. I recommend connecting all your equipment to surge protector power strips.
Mar 14, 2011 | RCA RP3722 Clock Radio
RCA RP5430 clock radio transformer TIN HING U2812-093-045E specs
It is 9v and 4.25v, measured from a working transformer in the clock radio
Dec 17, 2009 | RCA RP5430 Clock Radio
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
RCA RP5435B SN.1A006J255A0594-Clock running slow
Most of the Radio clocks by RCA are meant to be used with 60Hz AC line. This problem will not go away unles you can get a custom built 60 Hz AC power supply, may prove to be too expensive for the clock.
Sep 20, 2008 | RCA RP5430 Clock Radio
12:33 keeps flashing
Hi - You can download the manual from the link underlined in blue below:
moz-screenshot.jpgRCA RP5420
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 31, 2008 | RCA RP5420 Clock Radio
22 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
