Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
Problem with battery/unknown
My blackberry pearl flip has a crossed out battery when plugged in charging and when it's unplugged it doesn't turn on at all. I've tried to just take the battery out and turn it on but it doesn't even go on still. The crossed out battery screen has never come on before until now.
    Scholar:
  • 55 Answers
Your battery might be deffective or your phone keeps sucking any power out of your battery before it can hold a good enough charge I suggest you hook it up to your computer via USB directly and if that doesn't work you might want to look into getting a replacement battery for your phone by either buying it yourself or seeing if your warrenty covers it.
Posted on Jul 10, 2009
Last night my blackberry pearl flip 8230 wouldnt let me open my text messages, so i figured it just needed to be restarted, so i pulled the batter waited for a couple seconds, and put it back in. but...
hi,
dont panic .i think your battery is fully drain.it will not charge whatever you are doing so you need to charge it in a desktop charger..unplugged your battery and put the desktop charger and wait until it was full charge..
i hope it will help you ,thanks for trusting fixya
Jan 27, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
I have a blackerry flip phone just blinked out and i cant get it 2 come back on, the red light comes on 4 about 10 seconds and goes back off, help please !!!
staeyevans55 HI soorry to hear your having problems with your pearl. I need you to make sure you back up yout information on your phone. Use the blackberry desktop manager . If you are getting power to the phone we will be able to save your contacts. Now if you have a memory card take it out of the phone. I now need you to plug the phone in see if it is charging. charging port may be bas on your pearl. You will have to see if you can buy a replacement battery. This will tell you if the phone is working properly or not. A fully charge battery in the phone can help you see if it is charging properly . Another tip clean the connections and the charging port with can air and a toothbrush. their could be corrison on the in the port or on the contacts. Hope this information help
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Nov 28, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
My blackberry pearl flip shuts off and a red light
it has to be upgraded and you will lose all your data once it is upgraded it will work fine
Jul 21, 2010 | RIM BlackBerry Pearl Smartphone
My 8230 phone will not turn on put battery in and
A red light on a blackberry means the battery is flat. (Requires re-charging)
If you are confident your battery is FULLY charged and your charger is working then you may need to take your handset to a repair shop.
Try charging up the battery whilst in the handset. Let it charge for 30 mins then try and switch it on.
Remember...Blackberry handsets take longer than most to start up.
Jul 05, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
My blackberry pearl 8220 flip does not last enough even though I charge it daily for the amount of charge needed.
If your not using bluetooth make sure it's turned off, and check your screen settings, brightness and backlight time, perhaps you could find a setting there you can save power with.
Jun 02, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
I have a 6-mo old Blackberry Pearl Flip 8230 that
first try replacing the batteries with a fresh one, having a battery logo with a lightning strike states that the batteries, including the backup battery has completely dried out, try charging it for a few hours. if there is no change and you still get the logo, maybe it would be safe that you should have it check at blackberry repair center.maybe some shortage or busted parts are causing such an error on your blackberry.
Jun 01, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Screen won't turn on
try charging it. once you hook up the charger and plug it on the wall switch, it should turn on if it doesn't wait some seconds and turn it on.
if that doesn't help remove the battery from the phone and put it back in, it should turn on and reset.
Feb 14, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
I want to unlock my 8220 blackberry
Here are the updated instructions to unlock the RIM Blackberry Pearl 8220 (Flip):
Read more: http://www.mobileslate.com/blog/2008/11/04/how-to-unlock-blackberry-pearl-8220-flip/#ixzz0fNwiPynn
hope this helps! have a great weekend!
Feb 13, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Phone turns off every couple minutes and then turns on by itself.
What I would do is turn it off completelly for a few minutes. take out the battery and let it cool down for a few minutes. If you have a battery that if fully charged put it back in and turn on your phone. if your battery is not totally charged, charge it. A phone whose battery is not fully charged may cause your phone to flip out. sometimes it's also water damage to the phone that causes it to turn off on its own.
Water damage happends from body heat, from taking it to the bathroom when you're in the shower, or from putting it directly in water.
Hope this helps.
Mar 25, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
398 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
