Question about Measuring Tools & Sensors
How do i get the drive pulley off of a briggs and stratton 25 hp ELS motor
  • 225 Answers
SOURCE: I have a 20 Hp briggs & stratton motor it will
have you checked the oil ?some units have an oil sesor,that if oil level is to low shuts the unit down to stop damage to unit.
Posted on Jun 21, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
ftw1952
  • 10319 Answers
SOURCE: my 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Posted on Apr 03, 2010
  • 3 Answers
SOURCE: what kind of oil does the 22 hp briggs stratton
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Posted on Apr 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: How can i remove the drive pulley on the 12.5 briggs and stratton
Hi Steve, There should be an allen head set screw (Sometimes 2) that has to be removed before the pulley will come free. One set screw should be directly above the key way "key" and the second one (If installed) will be within 90 degrees of the one securing the key. Also take a piece of 100 or 120 grit sand paper and sand off the rust areas on the old crank shaft. Occasionally it does require a puller to get them off but usually you can tap gently the pulley every 90 deg (not on the pulley V belt drive area) and it will come free.
This should be a 13HP 2 cyl engine.
Depending on the type pulley they are using. Some of them have a collar on the crankcase side of the pulley that will also have to be removed. (again secured with a set screw possibly 2)
If it is really stubborn you can and should use a puller to remove the pulley. Be very careful if you do have to use a puller; not to damage the V-belt drive area of the pulley.
Thanks for using FixYa.
Kelly
Posted on Apr 29, 2010
130000 series 5 hp. Where can I get a belt and pulley diagram?
Pulley Removal - YouTube
? 4:29
https://www.youtube.com/watch?v=2LvXESviKlQ
Jun 17, 2009 - Uploaded by nannyberries
Remove Pulley from Briggs motor. ... You could also wrap thebelt around the pulley and hold the belt real close to the pulley. 1/2 inch Air
Nov 06, 2015 | Briggs & Stratton Garden
Where can you buy a new motor to replace a Briggs & Stratton 21hp ELS 656 V-Twin
These can be purchased from any authorized Briggs and Stratton dealer if they are still an active part. Also try 800-487-5951 they are a Briggs and Stratton dealer of parts and engines.
Jul 07, 2014 | Husqvarna Garden
Removal of carburator from model 303447-0446-01 engine
How can I remove the drive shift pulley on a18hp Briggs & stratton engine
Feb 05, 2014 | Briggs & Stratton Briggs Stratton Intek V...
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
Have a 22 ohv B&S els 725 v twin want recharge a new battery
If you want to recharge a "new" battery you should use a trickle charger and leave it on over night. Remove the ground side wire from the battery before charging. let us know
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B&S ELS 725 on a Husq 2448 lawn tractor - stoppe running won't st
There is no oil pressure switch to save the motor. You may be ok if the oil level did not drop too low. Change the oil, recharge the battery, put in a new spark plug and fresh gas. You may be lucky and have it start with no damage. good luck
May 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
My Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
Apr 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I am trying to get the 11 hp Briggs & Stratton engine out of my Toro tractor to replace the gaskets, since it is using & throwing oil over abundantly. How do I get the drive & mower pulleys from under the...
On the end of the shaft that comes from the motor there should be a bolt that holds the pulley in place. You will need to remove the bolt in order to get the pulley off. If you can lift the front end onto a couple of blocks it will make the job easier to do. You may have to place a screw drive in between the belt and the pulley. A wood wedge the width of the belt would be better as it would be less likely to damage the pulley. Depending on how old the tractor is, you may have to spray the bolt with a penetrating oil first to help loosen the bolt.
Hatter1
Mar 14, 2009 | Briggs & Stratton Garden
Measuring Tools & Sensors Logo
147 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
