Question about Kitchen Appliances - Others
I make alcoholic slushys with my Bunn 2 double hoppers. I have 4 machines. 1 works great. 1 freezes well but gets a huge amount of ice build-up on the outside, and the other freezes but thaws out a
I need to get it figured out before the nice weather hits!
  • 2,237 Answers
The ice buildup is from the brix level being too high. the mix is too rich to freeze fast. it freezes based on torque, not temp, so it'll just keep getting colder and colder until it's thick enough. once it gets below 24 degrees, the condensation on the outside will freeze. the other, check the defrost time.
Posted on Sep 08, 2014
4 Suggested Answers
Cuisinexpert
  • 61 Answers
SOURCE: I need the instructions for the slushie maker.
Check out your manual. Usually, a manual will have recipes for you to use. If you don't have the manual, you might want to look into contacting Bunn to get one (usually they can send them out for free!). Their phone number (according to their website, www.bunnomatic.com ) is 800-352-2866
Good luck! :)
Posted on Aug 26, 2009
projdoc
  • 2237 Answers
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
EsWorld
  • 1618 Answers
SOURCE: why does my ultra bunn 2 slushy machine throw off
Check the filter in the back of the machine that and the coils are covered with dust.
Posted on Feb 19, 2011
Hi does anyone know anything about the frutina slush machine. Ive just bought a preowned one. Im not sure its working right and it didnt come with instructions. Thankyou
Well I live in Southampton, and Ice Frutina are based here. The liquids come in great big containers that you just pour in ready mixed I think (or perhaps its from concentrate, I'm not sure) but either way the mixing instructions should be on most slushie mix containers. For the machine to make slushie you basically need two things to happen...
1) the powerful refrigerator within the unit should function and chill/freeze the liquid in the hopper
2) The agitator should be constantly turning inside the hopper to break up the ice crystals as they form turning the liquid into slush rather than just a block of solid ice.
If the refrigeration is working, you should notice a pretty quick drop in temperature of the liquid in the hopper... It may be worth checking any fans are working properly and not seized up. Check the refrigerant compressor is humming.
That's about as much as I can help you I'm afraid. Hope it ends up working for you :)
Jan 07, 2017 | The Kitchen Appliances - Others
Setting constitancy of product
I think your Bunn machine is producing the 'ice frozen drinks" it was designed for.
May 18, 2016 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
Get maintenance and shaft seal off diplay
hold down the word "gourmet" near the display for 5 seconds and release when the words change. it is a hidden button to get you into the menu. press and release until you get to the "pm" question then press "ice" for yes. keep hitting gourmet until it goes through the menu and the machine restarts. this will appear every 6 months to make sure you check your seals for leaks. if you have product flowing out of the bottom or side vents of the machine, replace the seal between the auger and the drum
Sep 08, 2014 | Bunn Ultra-2 HP High Performance Slushy /...
I have bunn slush ultra 2. 1 side freezes 1/2 way, like slushy a little bit but still watery, other side is only chill. both are set to 16 thickness.
make sure both say "ICE" on the display. press the snowflake buttons on the front to get it there. also, make sure you are mixing the product properly. if still an issue, you may have a small refrigeration leak that should be looked at by a professional
Aug 26, 2013 | Bunn Margarita Machine Ultra 2 Slush...
I have a 2 hopper bunn ultra 2, both sides are icing over on the outside
the mix is too rich. add some water to each side. it freezes based on torque, not temp.
Aug 17, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Bunn won't freeze the drink, the drum freezes and ices over but 3 hours later no slushy.
clean the filter and condenser coils, leave at least 6 inches of space for it to breathe
Aug 02, 2013 | Bunn Margarita Machine Ultra 2 Slush...
I have a bunn ultra II double hopper. neither side is freezing as well as it use to be, they both get chunks of ice in them, however the augers tend to **** instead of run smooth from time to time. i have...
go into the menu (hold down the "gourmet" button) and select reset all. then check your mix to make sure it's the proper ratio. too lean will cause it to freeze too fast.
Jun 12, 2012 | Bunn Margarita Machine Ultra 2 Slush...
Parrot ice slushie machine Compressor comes on,
Liquid gets very cold but won't freeze
Jun 10, 2010 | Freezers
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
Good luck! :)
Aug 26, 2009 | Bunn Margarita Machine Ultra 2 Slush...
Kitchen Appliances - Others Logo
147 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
