Question about Sewing Machines
Bernina aurora 430 the sewing light dosnt lite and the lcd display does not light up. They both stopped working at the same timd so iassume the two problems are connected. This machine hes one large printed circuit board and a couple of much smaller ones.I cannot find the part number of the large circuit board anywhere. I was told by a sewing machinerepairman that this is probably where the problem is. Is that correct? and if so could you provide me with the correct part number of the circuit board.dosnt operate
SOURCE: Bernina Aurora 430
I figured out the solution for this issue. It all has to do with the threading. And I mean literally follow the instructions word for word. Most importantly is the Bobbin thread. make sure to thread the bobbin through the case eyelet.
Posted on Mar 29, 2008
  • 6 Answers
SOURCE: Bernina 910 sewing machine extension table
Hi Phoebe,
What you have is the extension table for the 830 and the 830E Bernina models. What you need is part number 301 276 100. This table looks a little different as it has a small see-through window in the bobbin area and also, it has no clamp (it has push-in pins). Ebay or a site like SewItsForSale is your best bet. I doubt the dealer could get one but if they could, it'd be likely around $100.
Posted on Jan 17, 2009
SOURCE: Bernina 430 aurora will not sew, beeps when pedal is pushed...
Ok, I feel like a fool but I figured out the problem. I didn't have my presser foot down! duh!
Posted on Mar 12, 2009
  • 980 Answers
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
Posted on Nov 04, 2009
SOURCE: Bernina 730
I have lost the cord lead to my Bernina 730 sewing machine and cannot get any spares locally. Can anyone out there help find a replacement.
Posted on Feb 04, 2010
Bernina Aurora 430 sewing machine that the sewing light and the display went out on at the same time. I assume the problems are related but not sure. Was told that the main circuit board was the problem...
That's probably true if there's not a fuse or circuit breaker on the machine. Alas, if anyone but a repair shop opens the case, you've voided the warranty, so I'd look hard for a circuit breaker on the machine and then if that's unsuccessful, drag it in for repair. With luck, it's a loose board.
Apr 22, 2014 | Sewing Machines
430 aurora
Probably too thick to feed without dislodging the bobbin case, causing the error message.
May 07, 2013 | Bernina Activa 140
Bernina aurora 430 calibration problem
The complete manual is available at:
http://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/aurora/Manuals/032907-52-04_1103_a430_a440_a450_EN
A reset can be done as follows:
press the clr button. The altered stitches will be set to basic when you turn the machine off
May 21, 2017 | Bernina Artista 180
Aurora 430 Bernina
Hi, possibly your feedogs are dropped and in the darning position and/or its thinking you want to embroider and there is NO hoop attached or entire embroidery unit plugged in. Check your feedog button below the handwheel on the bottom.
Rick
Jul 29, 2009 | Bernina Sewing Machines
Bernina Aurora 430 utomatic button hole
Take it to your local bernina dealer and have them calibrate the buttonhole foot along with the speed control.
Jun 07, 2009 | Bernina Artista 180
Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Mar 26, 2009 | Bernina Artista 180
If you took the door off check and make sure the lower thread sensor on the door is snapped on correctly. Many times it gets put on beneith the bar rather than over it.
Nov 27, 2008 | Bernina Activa 140
I have a Bernina Aurora 430 (not on your list). For some reason, the feed dogs have dropped. The button that usually drops them isn't working.
If you remove the metal plate on the bottom of your machine, you can see the workings of the feed dog raise and lower button. With some luck it just might be a screw that came out or it might be a broken spring inside the sewing arm.
Without a service manual or a view of what it should look like inside when it is functioning correctly, at best you would just be guessing. It should be a simple 5 min fix but it is best to take it to a Bernina dealer for proper repair. Good luck, bushvideo
Aug 17, 2008 | Bernina Artista 180
Bernina Aurora 430
Jan 11, 2008 | Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
