Question about JVC KD-G320 CD Player
I need the hook up cables from the unit I have, jvc # kd - g320
informatica
  • 1114 Answers
SOURCE: how set time jvc kd g220
Hi - You can download the manual from the link underlined in blue below:
jvc kd g220
See page 10.
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 21, 2008
soundinstall
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Posted on Mar 02, 2009
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Posted on Jun 10, 2009
etirbynnor
  • 655 Answers
SOURCE: I NEED A WIRING GIAGRAM BECAUSE THEIRE IS NO COLOR
Hello nls124,
You can download a copy of the manual here at Crutchfield. The wiring color code is on page 31.
Vehicle wiring harnesses and color codes change frequently, but most likely you can get an aftermarket harness by Metra or Scosche that will fit your vehicle. That way, you can make the splices to the harnesses and avoid cutting or tapping into the vehicle wiring. Both www.crutchfield.com and www.sonicelectronix.com have harnesses for most makes and models.
Hope this helps.
Posted on Jun 11, 2009
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
Manual for jvc kd-6320
I don't see any references to a KD-6320 receive. Please check the model number. JVC has a KD-G320 AM/FM CD receiver. The installation and instruction manuals are available from the product support page here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027623 . The direct link to instruction manual is http://resources.jvc.com/Resources/00/00/93/GET0349-001A.pdf . You can also check here: http://books.jvc.com/ for JVC manuals.
I hope this helps.
Apr 02, 2016 | JVC Car Audio & Video
Cd player no longer reads that a cd is plugged. can I fix that?
Try resetting the deck by unhooking the connector. Every deck I have had will reset and spit the cd out when you hook it back up.
Jan 29, 2014 | JVC KD-G320 CD Player
JVC KGD 320: I don't have the owner's manual. How do I set the clock?
Hello there, The product model is refereed to as KD-G320 as opposed to KGD 320 which you provided. This made it a little difficult for us to get. But here is a complete user guide for the unit.The instructions to direct you on how to set the clock can be found on page 13. First you would have to turn off the satellite radio adjustment system which the unit has inbuilt to it.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Aug 23, 2011 | JVC KD-G320 CD Player
Can i get a replacement part for the kd-g320 all i have is th faceplate
The only way you are going to find another chassis is in pawn shops or garage sales. You are better off buying a new radio.
May 20, 2011 | JVC KD-G320 CD Player
Where is the reset button on the jvc hd-g320
hold and press the "sel" button and the "att" buttons and the same time to reset. Please rate.
May 17, 2010 | JVC KD-G320 CD Player
I NEED A WIRING GIAGRAM BECAUSE THEIRE IS NO COLOR TO COLOR PATTERN ON BACK OF MY JVC-KD-G320
This may help your cause
http://www.nodevice.com/manual/JVC/page24.html
Jun 11, 2009 | JVC KD-G320 CD Player
I have a jvc KD-G320 deck and need help hooking up subs...
Hello c92bivens,
While your KD-G320 does not have a specific subwoofer output, Kenwood did make provisions for adding one. There are two stereo pairs of line outputs on the back, one each for front and back. On the set for the rear, you can select a "line output mode" of "REAR" for normal speakers, or "WOOFER" for operating a sub.
Page 14 of your owners manual details the setting procedure while page 31 shows the connections. The manual incorrectly refers to the FRONT line outputs on page 14. Use the REAR line outs instead. If you do not have a manual, you can download the PDF version here at Crutchfields's web site. Ignore the "DISCONTINUED" notice (it's an old head unit), and scroll down the left just under "What's in the box" and click the "download owners manual" link.
Hope this helps. If it does, please rate as "FixYa".
Apr 25, 2009 | JVC Car Audio & Video
I have a jvc KD-G320 cd player and i am trying to hook it up to my 2 12" subs n the cd player doesnt seem to b sending the message to the subs to kick is there anything special i have to get to make...
ok first make sure all the leads are good
remote
and rca leads
check power to amp
then go in to settings in the head unit and change from rear to woofer and then do sub contol on high
Aug 16, 2008 | JVC Car Audio & Video
Settings
hola, nesesito ayuda para poner la hora a mi estereo jvc kd-g320 ya le busque por todos lados y no le encuentro.. si alguien puede ayudarme, se lo agradecere... gracias.
Feb 04, 2008 | JVC KD-G320 CD Player
My l/o works but my speakers running from head unit does not
You have to find the subwoofer setting on your head and turn it all the way up.
Aug 26, 2006 | JVC KD-G320 CD Player
JVC KD-G320 CD Player Logo
16 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
