Question about Refrigerators
My refrigirator is not cooling - Refrigerators
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
Check coils underneath for dust Use skinny brush
and or thin vacuum extension to remove dust
Posted on Apr 22, 2014
There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Refrigerators
FREEZER IS WORKING OK, BUT REFRIGIRATOR IS ABOUT 10 DEEGRES CENTIGRATES. Serial Number LA93506717
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 04, 2011 | Refrigerators
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 02, 2010 | GE GSH25JFT
My air is not running correct.. blowing hot air out.. what can we do to fix this problem
hi
this may be because following reasons.
1. you might have kept the temperature selection switch in heater please check it.
2.there may be leak in the AC line which might have drained the refrigirant so no cooling effect.check the line for leakage.
3.the refrigirant used may be less which doesnt give much cooling effect.
4.the cooling fan which cools the refrigirant may not working or speed is reduced which may reduces the heat transfer rate
if my answer were useful to you please vote me.
Jul 11, 2010 | 2003 Hyundai Santa Fe
My Daewoo refrigirator's freezer is cooling but not the lower com
sounds like you need to replace the ptc overload on the compressor as this component supplies start and run power to the compressor and its getting weak and short cycling the compressor,they just unplug and plug into the side of the compressor and when you remove it shake it by hand and if you hear it rattle thats a good sign its bad
May 31, 2010 | Refrigerators
Freezer (top) is cool, but refrigirator at room temperature
Your first step is to make sure the condenser coils and the fan are clean and there is nothing blocking air flow around the outside of the fridge. A good vaccuming and brushing will do it wonders.
If this does not improve the operation. Tell the landlord that it is bad and if it is part of the supplied appliances, he should replace or repair it for you.
If he is not cooporative, do some online searches for methods to convince him to do his job or who to contact to ensure he doesn't cause you harm.
Sep 20, 2009 | Whirlpool ET4WSKXK Top Freezer...
Refrigirator is not cooling. Freezer is cooling
if you have a bottom freezer, you need to defrost the unit the cool air from the freeezer is what cools the top part, but the channels are iced up
unplug the unit and let it thaw out overnight
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
