Question about Maxtra Trimmer 30cc 2-stroke Gas Pole Saw Chainsaws Chain Saw/Pruner
Parts Do you know where I can purchase the plastic chain guard and plastic boots for the gas tank support for my Maxtra pole chainsaw?
  • 20 Answers
This pole breaks because the gear inside is made of puter and when it gets warm enough it melts or breaks the teeth the only solution is to take it out and find some place that makes them to replace it
Posted on Apr 26, 2014
  • Ricky Garry Kelly Jul 22, 2014
    John I don't know where you are situated but if in australia send a msg to "pac pines" on fb he supplies numerous parts to me and you will find it hard to beat his prices. My chains retail at $44 his price $22.50 all the best.
Maxtra chainsaw parts
We added an O-ring to the gas cap, used a Goof-Off cap to replace the bar oil cap, added a flat-washer to hold the plastic saw cover. Since the pole joints slip out of place, he used very short self-tapping screws (made for steel studs) to fasten more permanently. He started the holes with the screws, but then backed them out and shortened them by grinding off 3 threads. Then he tightened them.
Mainly, we just found the problem that solves the start / fuel issues many have had on the Maxtra Pole Saw!!!!!!!! My husband noticed the carburetor seemed giggly. He had removed the air cover and been starting it by pouring a little mixed fuel directly into it, It would run a little bit, then die. I watched the fuel line, and even after pumping it up, it would get air bubbles in the line while it ran, and then drain completely. The fuel line is really short so we both thought it just might not be far enough into the fuel -- but that was not it. He saw the two nuts inside the breather and decided to remove those and the carburetor. A little tricky if you have NO mechanical skill at all, but really pretty easy, take photos if you need to remember how it goes. He found that the manifold piece behind that had 2 bolts holding it and they were VERY loose. This created a horrible air gap. He gently tightened those bolts with a hex bit keeping in mind he did not want to strip them. (Now we wish we had used Lock-Tite). We put it back together, pumped the primer AND IT STARTED ON THE FIRST PULL!!!! First pull, ran continuously, and even idled!!!! We are going to replace the fuel line with a little longer tube tomorrow. This baby will hum now!
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Maxtra long pole hedge trimmer has bolt with stripped thread.
same thing happened to me, I had to make another one there made of some kind of puter
Apr 07, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
My Maxtra 30cc pole pruner starts ok and runs fine for about 5 mins. The revs then begin to race and the engine cuts out
I have seen this issue before, having trouble remembering the fix though. Is there any more info you can give me about the problem?
Apr 14, 2013 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Chain came off a 14 mcculloch how to put back on
Hi, you need to remove the plastic guard on the side, held in place by a nut and a screw. Replace the chain around wheel and chain guard, loosen tightening screw, replace plastic conver, and tighten tightening screw. Make sure you have the chain the right way round, there is usually a small diagram showing this. Hope this helps
Jul 12, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
My Baumr Ag sx62 leaks bar oil.
The white plastic thing you talk about is spare impeler for the chain oil pump, but you should find it is a different thread which will slow down the oil flow, well it did for me. i have owned one of these saws for three years now and it still goes like a freight train. before you put them to use you must make sure the carby is set right. because if its running to lean or not enough oil in the fuel, Yes it will seize every time. All you have to have is a little bit of an understanding in small engine mechanics. Yes they do leak a little oil, just fill it when you want to use it. a chainsaw should use one tank of fuel to one tank of oil, no more than two tanks of fuel to one tank of oil.
Mar 06, 2010 | Garden
Remington electric chainsaw is leaking oil. How
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then clicked search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown"
It may help answer yuor question. RemingtonPower has production and replacement parts are very to find.
I've 7 chainsaws. 6 of them empty the oil tank overnight if I don't empty it. HTH
Lou
Nov 11, 2009 | Remington Electric Chain Saw
Remington electric pole saw stalls in vertical positon
check the bottom of the chain guard, look for a loose bolt just inside the housing.
Nov 02, 2009 | Remington Polesaw Wizard
Maxtra Trimmer 30cc 2-stroke Gas Pole Saw Chainsaws Chain Saw/Pruner Logo
226 people viewed this question
Top Maxtra Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Maxtra Garden Expert? Answer questions, earn points and help others
