Question about Sharp LC60LE810UN 60 in. LCD TV
Sharp lc60le810un turns on but black screen and won't respond
Turns on but it has a black screen with no response to controller or touch buttons
  • 102 Answers
SOURCE: my sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Posted on Feb 01, 2010
  • 11800 Answers
SOURCE: sharp lc-19sb225u tv turns on with a "white noise"
The blue screen means the processor of the tv no longer finishes the loading of the firmware - hardware fault, either the chip that stores the firmware or the processor have failed.
Since the chips are soldered on the mainboard and cannot be removed separately that means that the entire mainboard will have to be replaced. This is it
http://www.partstore.com/Part/Sharp/Sharp/LC19SB25U/Sharp/Sharp/DUNTKE352FM02/New.aspx
Now you must decide if it's worth paying $400 for a replacement board or it's better just to buy a new tv - i'm for the second option.
Posted on May 17, 2011
jdvillanueva
  • 2098 Answers
SOURCE: im looking for a power
Check this LINK. Please verify the actual part no of your board that is printed on the white sticker on the board itself to ensure that you will get the right board for your unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Sep 15, 2011
ladywinn
  • 5138 Answers
SOURCE: I have a sharp tv model/ lc-32sb24u. When u plug
Look for Bad Capacitors they will be vented or swollen on TOP.
Posted on Oct 18, 2011
vinceisaac
  • 2432 Answers
SOURCE: sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Posted on Sep 22, 2012
Sharp aquos no power buttons on set
No. the power button on the TV will turn it on, change the channels and the volume.
May 24, 2014 | Sharp LC60LE810UN 60 in. LCD TV
Control panel not responding
Your spa side touch pad/ topside control panel is failing. It is only a "Communicator" the buttons are shorting between them. This is usually the problem when symptoms are manifest like yours.
Jan 26, 2014 | Dream Maker Spas Pool & Spa
No image. seems to be a led problem
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ·This will reset the TV in order to fix the problem.
    ·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
    SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
    LONG STRIP (49 LED's)
    FRONT SIDE BACK SIDE RL 94v-0
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    SHORT STRIP (30 LED's)
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Dec 06, 2013 | Sharp LC60LE810UN 60 in. LCD TV
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
Huawei m866 touch screen stuck on android touch doesnt work
MOBILE PHONE TYPE> HAUWEI M886 ANDROID SMART PHONE
SITUATION > TOUCH SCREEN NOT RESPONDING I CANNOT PROVIDE MAINTENANCE TO MOBLE PHONE... IT TURNS ON BUT CANNOT MAKE SELECTIONS
Jan 22, 2013 | Huawei M886 Mercury - 4GB - Black Cricket...
The on/off light on the bottom middle screen is blinking one solid time and then one fast time. The tv wont come on with the panel or remote.
2)Press Volume DOWN HOLD ALL three buttons until LED stops flashing and then release.
Sharp LCD/LED parts web site -
Copy this link:
http://www.encompassparts.com/item/8459814/SHARP/RUNTK4459TPZZ/LEDPWBUNIT(LC-60LE810UN),_X4
E329419
1029
LFa
Sn-Ag-Cu
Ps-1
K4458TP
4458ZZ
0921FM
104863
ee03A
RL 94v-0
E329419
1025 LFa
Sn-Ag-Cu
Ps-1
K4459TP
4459ZZ
0714FM
302213
Mm05A
Dec 27, 2012 | Sharp LC60LE810UN 60 in. LCD TV
Sharp aquos won't turn on
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
How to reset LC60LE810UN
How to perform a cold hard rest on the Sharp LC-60LE810UN TV? It won't power on and just blinks.
Apr 14, 2012 | Sharp LC60LE810UN 60 in. LCD TV
Wide screen button on the remote does not respond when selected. Some other buttons are lest responsive. Batteries changed.
Try the remote reset troubleshooting. You may need a new remote control
http://www.fixya.com/support/t5724015-not_able_turn_tv_remote
Feb 05, 2011 | Sharp Ga416wjsa Remote Control
My touch screen is not responding
My touch screen has not been responding but my navigation buttons are working. I'm not able to check my contacts too.. .
Oct 27, 2008 | Motorola Mobility MOTOROKR E6
Sharp LC60LE810UN 60 in. LCD TV Logo
74 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
