Question about Garden
After the winter my motor runs fine but no water pressure
My craftsman 2150 psi power washer worked fine last fall, after the winter months, the motor is working fine but im getting no water pressure out of the hose. Its leaking at the inlet and outlet. Do I need a new pump? Anyone know where to purchase a pump if thats the problem.
    New Friend:
  • 31 Answers
Did you drain the pump in the fall? Cracked housing or blown gasket.
Posted on Apr 23, 2014
  • 12 Answers
SOURCE: no water pressure
There is a injector valve in the water pump that is sticking. Remove this valve, grease the top o-ring and reinstall. Problem solved. Use pump guard in the future to prevent this problem from reoccuring.
Posted on Apr 03, 2009
  • 14 Answers
SOURCE: craftsman 4 hp 2150 psi pressure washer wont start
Go to www.karcher.com ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Posted on Mar 11, 2009
  • 5 Answers
SOURCE: Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Posted on Apr 25, 2009
  • 104 Answers
SOURCE: pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
  • 156 Answers
SOURCE: Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Posted on Jul 06, 2009
Is there a lubricant I can use to unstick frozen pressure washer pump?
If pressure washer got frozen over the winter, the pump is bad. replace! Use winter pump protector during winter storage!
Mar 29, 2016 | Honda 2500 PSI Gas Pressure Washer
No high pressure water coming from soap inlet
have one of these same problem last month had to pull the pump off the bottom and free up the pump then worked
Apr 15, 2013 | Craftsman 2550 MAX PSI Briggs & Stratton...
Stalling pressure washer
Make sure you have a strong water supply going into it. On the two I have owned, they would struggle and the motor would "rev up" quite a bit if there was even a slight kink in the supply hose, or if the tap wasn't opened all the way.
May 18, 2012 | Craftsman 2500 PSI Briggs & Stratton...
Will not start up when cold out have to warm it up to get it to start
i would check too make sure you have the correct motor oil usualy a lighter grade oil for winter months
Jan 02, 2011 | Northstar Electric Wet Steam & Hot Water...
I have a k7.91 pressure washer the motor runs but stops or pulses
This sounds like a problem with the pressure sensor which is located on the water inlet side of the pump. This switches the power to the motor when there is sufficient inlet pressure and water flow. This pressure switch can get partially siezed up, and not operate correctly.
You will need to dismatle the unit and identify the pressure switch, dismantle it and lubricate it with silicone grease.
Feb 28, 2010 | Karcher PSI Electric Pressure Washer
Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
No water pressure
Mar 22, 2009 | Karcher 2500 PSI Pressure Washer
Craftsman 4 hp 2150 psi pressure washer wont start
Jan 10, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
725 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
