Question about Epson Stylus Photo R2400 InkJet Printer
Check the I/F cable connection and power of printer epson r2400
  • 110 Answers
SOURCE: Epson R2400 too red
If you are encountering a red or magenta cast when printing from Photoshop, please try the following changes in the driver and color profiles.
1. Open image in Photoshop. If Photoshop prompts you with an "Embedded profile mismatch" message indicating that the image's color space does not match the working color space, DO NOT convert the image or discard the information. Choose to USE the embedded information, otherwise important data about the colors in your image will be lost.
2. Go to FILE, PRINT (WITH) PREVIEW. (PRINT OPTIONS in Photoshop6.) Check SHOW MORE OPTIONS. Instead of OUTPUT use the pull-down arrow to select COLOR MANAGEMENT.
-If printing in color, SOURCE SPACE should be an RGB format of some sort, ie "untagged RGB" or "sRGB". It may also reflect the profile used by the image's source, for example a digital camera or scanner ("sRGBie####").
-If printing in black and white, SOURCE SPACE should be a greyscale or black and white format.
-PRINT SPACE should be a profile that most closely matches the printer name to paper in use and cartridge loaded, for example:
"SP2200 Premium Luster PK" (PK = photo black ink. MK = matte black.)
"SP820 Photo Paper"
"EPSON Stylus Photo 960"
"SPR300 Prem Glossy"
-INTENT can be either Perceptual or Relative Colorimetric. (Experimentation will tell you which looks best. More details on the exact technical differences between these settings is available in Photoshop' HELP menu.)
3. Go to PAGE SETUP. Ensure your printer name is selected.
In OS 9.x or any Windows version, click PROPERTIES to view the printer's current driver settings. In PROPERTIES, configure the following:
-select Custom mode, then click the Advanced button. Turn printer driver's color management OFF here by selecting "No color adjustment".
-Pick appropriate output resolution, DPI, paper type and paper size in use.
-If printing black and white images with the SP2200, ensure color ink mode is selected.
In OS X, go the PRINT menu. Under "Print settings" be sure the appropriate paper type and dpi are selected.
-Under "Color Management" there should be a dot beside "No color adjustment".
Regardless of operating system, do not use the "Print Preview" from the Epson printer driver as you have the Photoshop preview window to work with.
You are now ready to print.
Posted on Aug 22, 2008
jacklee366
  • 541 Answers
SOURCE: Epson R2400 printer won't print
it looks like your wast pad in your printer is full so your printer need to be reset let me no if you dont have the software to do this if not i can give it to you
Posted on Nov 17, 2008
websnail
  • 419 Answers
SOURCE: R2400 EPSON PROBLEM
Yikes... lot of these lately..
The solution in this thread will provide the answers you need.
http://www.fixya.com/support/t1544015-epson_r_2400_top_trashcan_light_ink
Posted on Feb 15, 2009
SOURCE: Intel Mac: epson R2400
download the R2880 driver and use that for printing.  When you instal it, it is located in the Library>Printers>PPDs  It should work a lot better after you do that.
Posted on Feb 27, 2009
websnail
  • 419 Answers
SOURCE: How to change waste pads on Epson R2400?
The R2400 is quite an expensive printer and changing the pads would likely knock the printhead out of gross alignment so if you really must change the pads then I'd recommend getting it done at a service center (much as it pains me to suggest it).
The only time it's really essential to get the pads changed though is if you do a lot of borderless printing as this dumps ink straight to the pads and bypasses the popular external waste ink tank modification.
My recommendation would be to consider getting the printer serviced this once and then immediately install an external waste ink system to your printer and use the SSC or A10-IPR utility from Epson to reset the waste ink counter from there on in.
All the info you need is available via this link
Hope that helps, even if it is a little late..
Posted on May 06, 2009
How to replace an Epson R2400 power supply?
Replace adapter cable only, do not replace the power supply by your own ! tTake it to the nearest vendor representatives
Apr 22, 2014 | Epson Stylus Photo R2400 InkJet Printer
Epson R2400 paper and ink lights blinking red. Ink waste pad replaced and counter reset to 0. Lights still blinking red. Close inspection for any loose objects in printer but none found. Please advise....
Try to turn on your printer without the ink cartridges. When the printer starts and ask for the cartridges, put them back in.
(To remove the cartridges turn on the printer, watch the print head carriage move, when it is at the center quickly unplug the power cable, move the carriage by hand to a position where you can remove the cartridges, after removing the cartridges push the carriage to the right where it should be parked.)
Sep 02, 2010 | Epson Stylus Photo R2400 InkJet Printer
Epson R2400 will not turn on. Green light will not come on. Tried different outlets.
try to unplug then replug the power cord. if it fails your power supply might have already been damaged and most likely need a servicer to replace it
Sep 12, 2009 | Epson Stylus® R2400 InkJet Printer
R2400 EPSON PROBLEM
Feb 02, 2009 | Epson Stylus Photo R2400 InkJet Printer
R2400 foreign object error
return printer back you not gonna solve this problem this is head malfunction
Jan 16, 2009 | Epson Stylus Photo R2400 InkJet Printer
Nov 17, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson stylus k3 r2400
Hi Lisa
The R2400 has the choice of two black inks, MK and PK. One is for Matt printing, the other (called photo black) is for gloss.
If the printer has the matt cartridge fitted it only allows suitable options, including paper choice, to be selected. If you change the black cartridge from the MK to the PK one, you should then have the choice of gloss paper.
Rich
Oct 04, 2008 | Epson Stylus Photo R2400 InkJet Printer
Cannot print from my Intel based MAcBook Pro on my Epson Stylus Photo R1800
mac book pro has a usb cable right? you can actually use it to connect to the r2400 and then dont use a guten driver use the downloadable driver for r2400 for leopard instead
Macintosh OS X 10.5 drivers for your product are available for download from the Epson support site.
1. Go to the Epson support website (www.epson.com/support).
2. Select your product model and download the driver for OS X 10.5 Leopard operating system.
Note: Be sure to select the appropriate driver compatible with your system: PowerPC or Intel Intel based.
May 15, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R2400 InkJet Printer Logo
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
