Question about Craftsman 26 Hp 54" Deck Yard Tractor
Blades won't engage motor dies - Craftsman 26 Hp 54" Deck Yard Tractor
  • 656 Answers
Check for spark at the sparkplug by pulling the plug wire from the plug, now insert a phillips head screwdriver into the plug wire and hold by the handle so that the screwdriver is about 3/8 to 1/2 inch from the cylinder head or bolt. Have someone crank the engine and check to see if it sparks. If you have a good blue spark then that's a good thing. Next replace the spark plug with a new one. Spark plugs corrode when sitting in an engine for a long time and loose their ability to spark under compression, especially when they have been run for a whole summer. If this doesn't get your mower started, buy a can of Sta-bil. This is a brand name varnish and gel remover. Mix a little on the strong side and make sure to shake the unit to mix the fuel and Sta-bil. I usually mix a few ounces of gas and Sta-bil in a small squeeze bottle. Then I remove the fuel line and fill the carb and fuel line with this solution, which I mix about 1/2 ounce of, to the 2 ounces of fuel. Crank it over after replacing fuel line and see if it starts. Make sure the choke is on full, it will help it stay running till the mix does its job. Then close choke slowly. If need be get back to me with the Model number, series and year. Good luck I hope this solves your problem. Please post a solved comment on fixya, so I receive credit for the solve. This will increase my ranking on fixya.com That is how I get paid. By knowing I am helping someone!!!!
Posted on Apr 22, 2014
  • 79 Answers
SOURCE: 18 hp craftsman 2 44 inch cut engine dies when blades engage.
HI
Check wires going to safety switch under seat.
Posted on Apr 07, 2009
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
SOURCE: motor dies when engaging the cutting blades
I need help with this exact same problem. Someone please answer this question.
Posted on May 22, 2009
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Posted on Apr 30, 2010
Testimonial: "Hit on the head with such a simple solution"
  • 3911 Answers
SOURCE: Runs fine when blades not
If it has a B&S engine, and many do, try this. Remove one spark plug at a time and start the engine. If it runs with one plug, but not the other, then you have a dead cylinder. That is why it seems to run OK so long as no load is on it.
I have had 2 different mowers with B&S engines which bent the valve push rods on the left (as the driver sits) side of the engine causing the problem you speak of. And if you google this issue you will find that I am not the only person who ever had this scenario.
If you have the OHV type engine you can pull off the little valve cover, next to the spark plug, and see the rocker arms and the push rods behind them. Replacing them is about as easy as it looks, however setting the gap between the top of the valve and the rocker is best left to someone who knows what they are doing.
Posted on Sep 11, 2011
My blades will not turn on motor dies when I engage it
could be a bad safety switch. take it off and test.
Apr 11, 2017 | Garden
Why does my MTD tractor screech and die when I engage the blade?
Sounds as if the valves need adjusting... You will need a feeler gauge and find out what the specs are for that engines valves clearance...
Oct 11, 2015 | Mtd Garden
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Old Snapper Mower dies when blades engage now won't start
I would have to say the engine seized up, sorry!
Jun 06, 2013 | Garden
Serviced my riding lawnmower runs great. but when I put in drive it dies out. Also when I engage blades it dies out. No problems last summer. It won,t stay running when I do these two steps
Probably the seat safety switch. If it's not activated (from your weight on the seat) the engine is killed when you put it in gear, or engage the blades. Lift up the seat and check the switch - wires on tight? switch tightly mounted? You can take the switch out and tape it in the pushed-in position to test things. If that doesn't let the mower run, the switch itself is probably bad, but it could also be a connector that knocked loose when you serviced the mower. Check wires and connectors. Good luck!
Jun 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Dies when blades are engaged
Is this on the grass, grass may be too long stopping blades from moving.
May 18, 2009 | Garden
Craftsman 26 Hp 54" Deck Yard Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
