Question about Casio Parts Cash Register PC Desktop
08 code ring up items a 08 code comes up and nothing else happens
  • Casio Master
  • 1,745 Answers
Brand and model?
Posted on Apr 22, 2014
Toshiba 2540c hangs on test mode D. When I enter codes nothing happens. How can I fix this?
There are new codes and old codes..depend on the firmware of the machine.....check your firmware and put codes that are working with that firmware
Mar 01, 2016 | Toshiba e-Studio 2540C Multifunction Color...
Fuel Rail Leak
Did did you change the o-ring at the fuel line to fuel rail connector? Do that before you change the fuel rail. According to an e-bay seller who is selling a used fuel rail from his salvage shop, the following fuel rails are interchangeable.
300 05-10 Fuel Injector; 2.7L and 3.5L
AVENGER 08-10 Fuel Injector; 2.7L
AVENGER 08-10 Fuel Injector; 3.5L
CARAVAN 08-10 Fuel Injector; 4.0L
CHALLENGER 09-10 Fuel Injector; 3.5L
CHARGER 06-10 Fuel Injector; 2.7L and 3.5L
JOURNEY 09-10 Fuel Injector; 2.7L
JOURNEY 09-10 Fuel Injector; 3.5L
MAGNUM 05-08 Fuel Injector; 2.7L and 3.5L
NITRO 07-11 Fuel Injector; 4.0L
PACIFICA 05-06 Fuel Injector; 3.5L
PACIFICA 07-08 Fuel Injector; 4.0L
SEBRING 04 Fuel Injector; Conv, 2.7L, from 07/30/03
SEBRING 04 Fuel Injector; Sdn, 2.7L, from 07/30/03
SEBRING 05 Fuel Injector; Conv, 2.7L
SEBRING 05 Fuel Injector; Sdn, 2.7L
SEBRING 06 Fuel Injector; (Conv, Sdn), 2.7L
SEBRING 07 Fuel Injector; (Sdn), 2.7L
SEBRING 07 Fuel Injector; (Sdn), 3.5L
SEBRING 08-10 Fuel Injector; (Conv, Sdn), 2.7L
SEBRING 08-10 Fuel Injector; (Conv, Sdn), 3.5L
STRATUS 04 Fuel Injector; Sdn, 2.7L, from 07/30/03
STRATUS 05 Fuel Injector; Sdn, 2.7L
STRATUS 06 Fuel Injector; (Sdn), 2.7L
TOWN & COUNTRY 08-10 Fuel Injector; 4.0L
Mar 04, 2014 | 2007 Chrysler Pacifica Touring
Hi, I have an 08 Pontiac Montana SV6, when I come
shakes and stalls indicates an engine problem-take it to autozone advanced auto or pepboys and have them check your onboard cpu for fault codes-cheers Denny
Nov 02, 2013 | 2005 Pontiac Montana SV6
2008 town and country wont start
02 or 08 if its an 02 and its the original battery replace the battery you received 3 extra years on your battery . if you jumped the car incorrectly there is a fuse link under the hood that blows out to protect your system. if its an 08 take your battery out and have it tested at your local auto parts store, may need a charge if this does not work i need more info
ps if your headlights come on strong with no real dimming of the interior lights battery is usually ok, if the interior lights dim or go out baterry is usually in need of charge or replacement , must see what caused that to happen, need more info
Sep 16, 2009 | 2002 Chrysler Town & Country
Oil and filter changing for 08 sienna. How complicated is it?
You still have to drain the engine oil from the drain plug in the oil pan, and I recommend replacing the drain plug gasket.
If you buy a filter from Toyota, it actually comes with instructions on exactly what to do. There is a 3/8" recess in the bottom of the filter housing, when you put a 3/8" extension and a ratchet in this and remove it, there should be a plastic piece that comes with the filter to pop into the bottom of the housing and drain the oil. replace the o-ring and reinstall the housing drain plug.
You can get a filter-cup tool from Pep Boys or local auto parts tools sections that will fit the filter housing. Use the cup with a ratchet and extension to remove the filter housing. replace the filter cartridge and the o-ring. Make sure to lubricate o-ring, they will snag! Reinstall and add 6.4 qts of oil
Dec 29, 2008 | 2008 Toyota Sienna
Removal of front assembly (Maytag MAH6500AWW)
remove the front ,everything thats in front of the tub.Remove the fins attached inside of tub ,remove any bolt you see .Remove the tub
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Assasins Creed
Clean the disk, make sure there is no scratches than contact the seller of the item if you're sure it's perfectly fine-looking and tell them your story, they should trade it in depending on where you got it.
Jan 21, 2008 | Sony Playstation 3 (PS3) Console
Disc Reading Error
Does it have white/gray rings around the disc? if so, i can give you the answer
mick
Oct 18, 2007 | Video Game Consoles & Games
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
