Question about Nikon D90 Digital Camera with 18-105mm lens
D90 wont shoot in auto mode. gives me r21 error. Manual mode works fine
Nikon d90 with 18-105 lense wont shoot at all in auto mode. r21 error. Manual mode is ok. any ideas. Ive tried to turn the lense back and forth several times but nothing
  • kakima Apr 22, 2014
    Which lens(es) are you using? r21 isn't normally an error code but simply a count of the number of additional shots you can take in the current burst before the buffer fills up. You should still see the r and some number even in manual mode.
    Top Expert:
  • Nikon Master
  • 6,702 Answers
Did you switch the Focus-mode selector to MF?
It is the switch with number 8. Perhaps you are used to switching on the lens, but on the body is also a switch. Normaly used for the older AF lenses.
d90 wont shoot in auto mode. gives me r21 error. M - ef6bcbcb-fb5e-4e4f-8886-8b72082cffea.png
Posted on Apr 23, 2014
  • bernadette kirkpatick
    bernadette kirkpatick Apr 24, 2014
    THANK YOU!!! I had no idea that was it. Im just confused as a new user to the D90
    I thought if you are in auto mode then you switch to AF on the camera body and A instead of M on my 18-105 lense
  • 62 Answers
SOURCE: Slow Shutter Speed on Nikon D90
I suggest that you try a system reset for your camera and then complete the following adjustments to see if your camera will respond like it did originally.
Nikon D90 green reset dots. Press at the same time to reset.
Nikon has an easy reset feature. I use it every time I pick up a D90.
My standard operating setting is only a few clicks different from the reset defaults.
I reset everything every time I use my camera, much as a pilot uses a checklist before every flight to prevent any switches from being in the wrong position. When I don't check first, I often have left my D90 in some screwy mode, like 2,500K WB and ISO 3,200, from shooting in the dark the night before.
My checklist is therefore Reset, Program, Basic, Medium, and A3. Allow me to explain:
1.) Reset: Hold down the +/- and AF buttons (next to the green dots) for a few seconds, and the D90 comes out of whatever crazy mode it was in and returns to sanity. The top LCD blinks and everything is back to normal.
Reset leaves the detailed menu tweaks alone and resets only the big dumb things I might have changed overnight.
Once Reset, I change these next:
2.) Program: Spin the top left exposure mode dial to P, program auto exposure.
3.) Hold QUAL and spin the rear dial until you see BASIC, and spin the front dial until you see [M]. You'll always see these on the small top LCD, and if you first tap INFO, you can see it more clearly on the huge rear LCD. (Feel free to use other settings if you have a good reason.)
4.) Hold the WB button and spin the front dial three clicks to A3. This gives warmer (more orange) photos that I prefer.
Excerpt taken from: http://www.kenrockwell.com/nikon/d90/users-guide/index.htm
Good luck and happy shooting! I have a D80 and would love to get my hands on the new D90. Make sure you also buy a quality filter for your lens UV0. The quality of the lens is just as important as the body it's attached to.
OpenSource13
Posted on Apr 09, 2009
SOURCE: nikon d40 digital camera
So, before i take my d40 to an authorized tech, should i maybe see if the lense needs to be cleaned then? silly question I know. But i really dont want to waste money on sucha petty problem.
Posted on Apr 25, 2008
BubbaGuru
  • 70 Answers
SOURCE: F-- on Nikon D90's display
Lense and body connection problem...Try removing and replacing he lens. Also you can try to gentley turn the lens on the body to make the contacts touch better...
Posted on Jul 05, 2009
  • 7 Answers
SOURCE: Why is there a delay?? Nikon D90
Sounds like you turned on Exposure delay mode (menu d10). This is similar to the "locking up the mirror" (or somethign) feature on canons.
YOu only need it when you doing a tripod shot with long exposure and you want to minimise absolutly all possibility of shake from the camera its self. Lifting the SLR mirror will cause small shake. Generally you can turn this off (i've felt it ona few times my accident and been confused for a second)
Posted on Aug 21, 2009
  • 4 Answers
SOURCE: nikon d90 - can't take the picture
You just found the Nikon D90 F-- error message solution!
I had the same problem with the Nikon d90 F-- error message which drove me nuts!
I called Nikon, they walked me through a lengthy reset procedure which didn't work. After spending a few hours researching online, I found the answer.
It is not the memory card or nor a defective camera body. The lens does not need to be rechipped.
The F-- error means the camera is unable to communicate with the lens and is caused by a poor connection between the ground contact pin on the lens and the metal mounting ring on the camera. Most people buy the camera, install the lens once and then encounter the error. This one time lens installaiton does not give the contact point a chance to seat itself properly. You will find that if you hold down the lens release button and twist the lens as if to remove and reinstall the lens about 10 times that the problem will disappear. You don't even have to actually pull the lens away from the body, just press the release button and twist on and off and allow the friction to provide a better electrical contact.
Too bad Nikon doesn't tell their customers about this simple fix. Other than that, great camera. Good luck.
Posted on Sep 01, 2009
What is the relation of lense maximum apertures and camera settings?
You have not stated which model camera body you have so I can only give you general Nikon information. There is a range over which the automatic settings will work for each camera. In addition, Nikon bodies have multiple sensitivity ranges. On the D90 for example, go into the "Shooting Menu" and open the "ISO sensitivity settings." You will see "maximum sensitivity" and "minimum shutter speed" menus along with the "ISO sensitivity auto control" options. Turn off the auto control option and manually set the maximum (ISO) sensitivity and minimum shutter speed. Also, the Shooting Menu also has "High ISO NR" settings that can be used to accommodate most lighting situations. You need to look in your camera's manual for all the details. The Nikon website has manuals available for all the Nikon products.
Sep 19, 2012 | Nikon D3, D40, D40X, D50, D60, D70, D80,...
HOW DO I SET MY CAMERA TO AUTO FOCUS
The D90 has three different autofocus modes. In the AF-S mode it will not shoot until it has focused. In the AF-C mode it will shoot when you press the shutter release button even if has not focused. In the AF-A mode the camera switches between the AF-S and AF-C modes so either can apply.Also, bear in mind that the camera doesn't really know what you're taking a picture of. It may focus on something other than your subject. If you're in the single-area AF mode then you control which of the eleven focus points the camera uses. In any of the dynamic-area AF modes the camera decides.For full details on how the various modes work, please consult your manual. You might also check out the Nikon D90 video tutorial.
Apr 24, 2012 | Cameras
My d90 flashes an err sign somtimes when i shoot at manual mode.. but when i change my apperture and shutter speed setting, it will not appear anymore. Even at auto mode sometimes it flashes an err. Does...
Try shooting in manual mode with lens set at maximum (wide open) aperture. Then try at a smaller f-stop, say 5.6 or 8. If the error message appears when your lens is set to the smaller aperture, you could have a lens problem. Try another lens using the same test. If a known good lens gives an error message, then the problem is in the body. Also try zooming to different focal lengths and see if your 18-105mm gives the error at particular focal lengths. An error here would indicate a lens problem. In any case, your lens or body would have to be repaired by a professional as these repairs require major disassembly and re-calibration.
Nov 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have a nikon d90,when i pressed shutter button ,it is giving err message then i press second time it is not giving err message but not taking the photo.
This is an indication that the camera is not "talking" to the lens correctly. When you press the shutter button, the camera tries to focus, set light levels, and then shoot the picture. If it can't focus or set F-stop and shutter speed, then it can't shoot the picture and gives you the error indication. SO
1. You need to make sure the lens is an automatic lens capable of working with the D90. 2. You can take the lens off and back onto the camera a few times in case its a dirty contact issue or just didn't seat correctly. 3. Set the D90 to manual and make sure you move the AF selector on the front to M. Then you would manually adjust all the settings. That should take the auto-coupling out of the picture (pun intended)
4. If it still shows error when in total manual mode, there may be something wrong in the camera itself. Before giving up, do a total system reset on the D90 (I assume you have the manual).
Nov 15, 2010 | Nikon Cameras
My nikon D 90 whit an old lince 28-105 will not auto focks an offen not take pictuers. WHY not???? must i go too the shop wher i bought it or am i douing somthing wrong??? i am from Denmark and my englich...
Hi Annette,
The Nikon D90 will take pictures with many older lenses, however there are some problems with using these lenses. Most of the time, they will not auto focus and many depending on type lens may not work in any mode other than "M" (manual). No P, A, S, AUTO or any of the "Scene" modes.
Set to "M" (manual)
You will have to set the exposure values (aperture & exposure time) and focus manually. Ken Rockwell has compiled a list of lenses that may help you learn more about using older lenses with your D90.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 that does not want to shoot pictures
The camera may not be sensing that a lens is attached. Try removing the lens completely and then attaching it again securely.
Jan 17, 2010 | Nikon D90 Digital Camera with 18-200mm...
Vivitar telephoto lense 500mm
Yes and no. If it doesn't come with one, you'll need a T-adapter for Nikon in order to mount the lens (you can get one from Vivitar, as well as from other manufacturers). The lens is not an autofocus lens, so obviously you will have to focus manually. It's also a mirror lens so it has a fixed aperture. It's what Nikon classifies as a non-CPU lens, so you cannot use the D90's exposure meter. You will have to shoot in Manual mode.
Feb 18, 2009 | Vivitar Telephoto 500mm f/8.0 Mirror...
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Dec 25, 2008 | Nikon Zoom 80-200mm f/4.0 AIS Lens
Nikon D90 Digital Camera with 18-105mm lens Logo
147 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
