Question about Acer Aspire 5000 Notebook
Cpu Clock My CPU is starting at max clock, which causes laptop to overheat in 2 minutes (!) I have a Rightmark CPU clock utility that underclocks it to voltage 1100, but im curious about why does it start overclocked.
    Novelist:
    Champion:
  • 256 Answers
The CPU voltage in no way can be 1100 V, let us say about 1.100V? There are a lot of undercooled computers that people have bought. In fact of the ones that I have checked, they all needed just a little more cooling than to be pulling your hair later. You are lucky that you have a laptop. The laptops are the most overheated, to the point that some people came up with add-on cooling trays and other gadgets. I think that it would be ashamed to have your pride and joy go to an early grave because some dxdxd (to the cube) engineer let the marketeers insist in the smaller erything. Now, your only way to get some life out of them is to use one of these cooling trays. You don't have to buy it, you can make your own. The construction I have seen is very simple. Thank you for your consideration and your choice to use our service... My name is Constantin (arzconst is my internal nickname under Fixya.com).
Posted on Jun 19, 2009
  • CONSTANTIN SPYROU Jun 20, 2009
    My comment above is quite adequate. I have nothing to add...
Adjusting clock speed
buddy you must have to root your android phone,
then u will be able to increase or decrease ur clock cpu speed .
u can install an app from google play store like cpu enhancer ,cpu clock ,
Oct 14, 2014 | Computers & Internet
Hello im getting extreme overheatting on my acer aspire 5720z im using a cooler pad under my laptop, anyway sometimes it just shutdown. its clean too. how can i set up the fan to run all the time??
Try to clean the heatsink of your laptop to avoid dust. Unfortunately, there is no 3rd party utility to control acer laptops fans. You would have to clock down your cpu/gpu to avoid over heating.
Regards!
Nov 26, 2010 | Aspire Computers & Internet
My Toshiba laptop hangs when I plugin the power AC, but it works fine when running on battery. I am able to charge the battery when laptop is in sleep or shutdown mode. I have the latest BIOS. What could...
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Aug 27, 2010 | Computers & Internet
Motherboard ID 07/28/2004-KM266-8237-6A6LYM4BC-00 **Above mentioned is the motherboard id of my motherboard. can u please tell me how much of the DDR can i use on my board? m using now one 512mb and...
Maximum of 1 GB per slot.
Yes, you can buy DDR400, it will be underclocked by the motherboard to DDR266. If you want some extra performance you can go in the BIOS and lower the timings one unit.
Yes, they will work, but not very fast. They should be used only as a last option.
Aug 03, 2010 | MSI Computers & Internet
My acer aspire 5050 shuts down after using it for 20-30mins
CLICK HERE to know the causes of your laptop heating and how to solve it....
Good Luck.. :)
Jul 18, 2010 | Acer Aspire 5050-3242 Notebook
I have motherboard ms8137c with cpu 1.6 ghz but it works like on 950 mhz, what sould i do to repair that
All Athlons were until a few months ago named on a power rating, not actual CPU speed rating. Since you didn't tell me the exact type of your processor i believe that it's the actual , normal speed of your CPU. But if it isn't then it's underclocked. To verify that go in the BIOS and see if the FSB is the correct value - 133MHz - sometimes it's at the default value of 100MHz. This can be changed from 2 locations:
1 - the JP4 jumper on the motherboard - 2-3 corresponds to 133MHz (of course you should change it only with the pc is disconnected from the mains)
2 - in BIOS go to Frequency/Voltage Control - CPU Host Clock and set it to 133.
Mar 24, 2010 | Matsonic MS8137C Motherboard
My Toshiba Satellite A75-s206 shuts down by itself. When I feel the bottom it's burning hot. Could this be my fan not working properly? Please help.
I am a Toshiba Laptop Tech. The A75 in notorious for over heating. The fins on the heat sink get clogged with link much like you clothes dryer. This restricts airflow which leads to overheating and ultimately the machine will shut itself down.
The Solution:
By some canned PC air and blow in into the fans from the bottom.
If you are feeling gutsy, disassemble the machine clean the fans, heat sink and apply the thermo-heat grease.
Mar 10, 2009 | Toshiba Satellite A75-S206 Notebook
In setup
Here are the settings.
The fine clock ratio stayed at 0.5 after I loaded optimized defaults.
Robust Graphics Booster___________ [Auto]
CPU Clock Ratio ____________ [8]
Fine Clock Ratio ____________[0.5]
CPU Host Clock Control_ [Disabled]
CPU Host Frequency (MHz)__________ [333]
PCI Express Frequency (Mhz)_______ [Auto]
C.I.A. 2__________________________ [Disabled]
System Memory Multiplier (SPD)____ [Auto]
DRAM Timing Selectable_______ SPD __ [Auto]
Performance Enhance = [Turbo]
CAS Latency Time________________ Auto (7)
Dram RAS# to CAS# Delay_________ Auto (7)
Dram RAS# Precharge Delay_______ Auto (7)
Precharge Delay (tRAS)__________ Auto (20)
ACT to ACT Delay (tRRD)_________ Auto (4)
Rank Write to READ Delay________ Auto (5)
Write to Precharge Delay_________ Auto (10)
Refresh to ACT Delay______________ Auto (60)
Read to Precharge Delay__________ Auto (5)
Static tRead Value_______________ Auto (6)
Static tRead Phase Adjust________ [Auto] (0)
CPU/PCIEX Clock Driving Control [800mV]
CPU Clock Skew Control [normal]
GMCH Clock Skew Control [Normal]
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [normal]
PCI-E OverVoltage Control_ [normal]
FSB OverVoltage Control___ [normal]
(G)MCH OverVoltage Control [normal]
CPU Voltage Control_______ [1.25]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: N/A
x C4/C4E State Support..................: N/A
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Enabled]
Virtualization Technology................: [Enabled]
Integrated Peripherals
Legacy USB Storage Detect___________________[Enabled] *Note* Must be enabled to flash from USB
Hope this Helps, Please Rate My Response! Thanks!
PREM
Feb 20, 2009 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
Cpu
How is your cpu cooler? Sounds like it could be a heat issue. How long before it freezes? Will it actually boot through to the operating system or freeze on start up? If it runs for a while then freezes it sure could be overheating.
Feb 23, 2008 | Dell 2.8 GHz Second Processor for...
Unwanted Shut-off
First Charge up you battery while the computer is off. Once fully charged unplug the adapter and play the game...see if it shuts down. If not replace that ac adapter. If it still shuts down... Your unit is overheating most likely. When you play high tech games which cause the processor and fans to run harder once it gets to hot. And most times you can hear the fan running loud on your laptop. 1. check the system requirements on the game 2. Are you overclocking your processor, check your bios 3. Lower the graphics settings and features in your game.. see if it shuts down 3.Or while you are running the game do the follow hit ctrl, alt, del buttons at the same time. A task manager box will pop up. Click on the tab Performance.....what is your cpu usage? 100% if so it's running the proccessor hard. Now in the same box click on Processes, then user name, you will then see all processes that are running at that time. If you want to play the game off line...only!!! you can stop some processes from running. On the bottom right hand corner of your screen by the clock you will see icons that load up at startup. Right click the ones not in use, like virus scan, firewall, other background applications that are running by right clicking over the icon and exiting or closing the application. Now keep in mind before you go back on line you should restart your computer so your security software will reload. Other reasons would be internal cleaning, fan, heatsink replacements and so forth. Which may need to be performed by a professional repair shop. Now they do have a laptop colling pad which have worked for some people. Also these laptops can overheat quickly, do not sit them on beds, and your lap when using ventilation is important. And also you might still want to have that ac adapter checked out. If all else fail... restart you computer in safe mode...try running the game..see if it shuts down. Good luck with your games
Sep 15, 2007 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5000 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
