Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
No forward/reverse motion
First use this season.Tractor worked for 20 minutes but started slowing down until it eventually stopped. Towed to my garage and let cool for few days. Started it again, and was able to cut for 5 minutes with strained power . Eventually same problem, no forward/reverse motion. Have purged transmission few timesaver manual. Please help before I purchase ground drive belt or more without solving. Thanks.
  • 656 Answers
This sounds like you have a bad bearing in one of the blade hubs or idler pulleys. Check by turning each pulley by hand and see if it turns easily. Go around all the pulleys and blade hubs(where the blades mount) and check for ruff spots while turning, and that they all turn freely. Do this without the blade engaged, this will allow them to turn somewhat freely.
Posted on Apr 22, 2014
3 Suggested Answers
  • 13 Answers
SOURCE: I have a craftsman garden
Depending on the usage of mower it is possible that belt is worn and likely it is stretched just enough to permit slippage. Usually belts will squeal and even have a burning smell. While the engine is often check to see the mechanical actions on the belt and feel for slackness.
Posted on Feb 24, 2011
rockmeister
  • 2047 Answers
SOURCE: craftsman lawn tractor automatic transmission
Just like motor vehicles when transmission gets stuck on a particular place without moving forward or backward it is a sign of a jam in one of the transmission levers. This is usually caused by lack of transmission fluid in the gears.When the fluid or grease depending on what your unit uses gets low the levers begin to grind against one another and therefore bring about such problems as you are facing. Although there is an off chance that the problem could also be from the automatic selector in this case the damage might not be so much probably an electrical fault.
First get an expert to check the auto selector if it is in good shape. If it is then i am afraid the problem is from the transmission levers.
Hope this insight has been helpful?
Posted on Apr 14, 2011
RE LK 3504 (35 hp 4 wheel drive Tractor starts, runs 5=10 minutes under load, then slowly fades away running slower and slower until it stops. Restarts in 15 min, same result
Here is an idea.
It sort of sounds like there is a blockage after a while in the gas tank.
If there were sediment in the bottom of the gas tank, it would start and run fine sitting still.
However, when driving it, it would be a matter of a few minutes until the sloshing of the fuel would cause the sediment to mix in with the fuel, and clog the filter screen in the fuel tank.
When it stops, the sediment would settle back down, and in 15 - 20 minutes, it would be clear again.
God bless your efforts.
May 08, 2017 | Cars & Trucks
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
How do I get my outboard motor to go into neutral. It goes directly from forward to reverse without slowing down
Check your shift linkage somewhere there is a detent stop that's not working could be a broken spring
Sep 13, 2016 | Boating
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Steve
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
83 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
