Question about Seiki SE221FS 22 in. TV
Seiki tv menu keeps coming on
When tv is switched on menu appears--when channel is changed menu cones on . And it comes on by itself
  • John Fantozzi
    John Fantozzi Apr 22, 2014
    TV is older than 2 yrs. Doesn't get much use . Been doing this since purchased
  • joseph sullivan Apr 22, 2014
    john call them anyway they are very good about helping out maybe they will do something for you there number is in the manuel good luck Joe
I call kmart where i purchase it they was very helpful.thank God for good customer service the problem were solve.
Posted on Feb 11, 2015
  • 4 Answers
  • Seiki is very good with problems if you purchase your TV less then a year ago call them and they will take tv back and fix it no charge and they won't charge shipping either Good luck Joe
Posted on Apr 22, 2014
I have a 50 inch seiki tv model # sc50its. comes on shows the seiki picture on screen goes to one channel{cannot change channel} then shuts off. tried to reset by unplugging for a few days. no luck.
Check and replace its main system control memory IC. It is faulty.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Dec 23, 2016 | Seiki Televison & Video
When yuo turn tv on it just keeps flashing seiki on screen
Sounds like corrupted firmware. A firmware update migh make it right. If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Aug 15, 2016 | Seiki 32" LED TV - SE321FB
TV will not switch channels. Manually nor remotely. Hook up another TV everything works.
Most TVs have a manual or auto-program feature to add or remove channels. It is possible that you have de-programmed all or most of the channels.
Connect TV to cable or antenna, enter the main menu and look for auto program feature.
Apr 11, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
How to reset Seki tv when it goes off and will not come back on
Seiki hard reset tv factory settings Flat Panel Televisions ...
www.fixya.com > ... > Flat Panel Televisions
Seiki flat panel televisions hard reset tv factory settings related questions and answers. Ask your Seiki questions. Get free help from flat panel television experts.
How to reset a seiki hd tv that keep reading no signal? - The ...
www.askmefast.com > Family & Relationships > Singles & Dating > Signal
To reset your seiki hd tv you just need to press on the menu: 0000 The TV will ....Getting to factory settings seiki tv ..... "How to reset seiki tv that reads no signal?
FAQ's ' seiki
Dec 19, 2015 | Seiki Televison & Video
Do I replace the backlight itself, or the controller board or the main board in the TV?
I have the same problem. Most everything I can find says to replace the inverter board (which are pretty cheap) first. I got one on eBay for 10.49 with free shipping. Changing the inverter didn't work for mine but hope it helps you!
Sep 19, 2015 | Seiki Digital Inc. SE501TS 50" LED TV...
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Upper channels
Hi, Go into menue and change the off air channels to Cable. Then you should get more Channels. Hope that helps.
Mar 12, 2014 | Seiki Televison & Video
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Tune in channels
Switch TV on
Press “MENU” on remote until 3 blue arrows appear
Press “VOLUME” keys to tune up or down (shown on blue bar)
When required programme is tuned, input required Channel number (appears on 2 green lines at top) e.g. 02 or 14
Carry on tuning and allocating channel numbers
Select “MENU” to clear or wait until it clears by itself
Channels should now be tuned to allocated numbers
Feb 21, 2010 | Televison & Video
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
Seiki SE221FS 22 in. TV Logo
254 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
