Question about Sanyo Televison & Video
DP58D33 Power on sequence does not complete.
Panel power lamp turns on but power on cycle does complete. After several minutes power lamp turns off.
4 Suggested Answers
  • 1694 Answers
SOURCE: Is The Problem The Lamp Or Something Else
Research at www.HitachiServiceUSA.com ........T.
Posted on Nov 09, 2007
SOURCE: Sony KDF-E55A20 Lamp Shut Down with no blinking lights
If you TV is about 2 1/2 yr you probably need a new lamp they only last about 3 yrs. Mine popped one night and now picture comes in for about 1 min and goes out, I ordered a new lamp today they run $199. There is also a know issue with the thermal fuse. The part cost about $3 and if you know a lil about electronic you can replace it yourself
Posted on Nov 17, 2007
  • 8457 Answers
SOURCE: I have a 6 yr
No.The tv have a colors wheel is dead.The colors wheel make loud motor noises,squiling noises and flashes picture with black&white.The colors wheel is dying and spinning off of it motor axis.Hire a Tv Tech. to change the colors wheel.Because is require take out alots machanical parts,before u can even come to the colors wheel itself to replced.
Posted on Oct 23, 2010
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
Hello
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
Jul 24, 2011 | Televison & Video
Where is the lamp module located for a sony kdf 42we655?
Please read here: http://esupport.sony.com/US/perl/news-item.pl?mdl=KDF42WE655&news_id=84
From SONY:
If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it is time to replace the lamp with a new one (not supplied).
Use only a replacement Sony XL-2100U or XL-2100 for your TV. Use of any other lamp may damage your LCD projection TV. Contact your Sony dealer for a replacement lamp.
Click here to download step-by-step directions for replacing your TV's lamp.
Note: Before replacing the lamp, turn the power off on the main unit. Wait several minutes, then unplug the power cord. (The cooling fan will continue to blow for about two minutes after turning the power off.)
Be sure to allow the lamp to cool down completely before removing it. The surface of the lamp remains extremely hot for at least 30 minutes after the power has been turned off.
Mar 10, 2011 | Sony KDF-42WE655 Television
How to replace lamp
hi,
1.Turn off the power on the main unit. Wait several minutes, then unplug
the power cord.
(The cooling fan will continue to operate for about two minutes after
2.Wait at least 30 minutes after unplugging the power cord to allow the
lamp to cool down before replacing it.
Take the new lamp out of the box.
3.Remove the Front Panel Cover.
4.Pull out the lamp.
Loosen the screw on the lamp cover with a coin or similar object to
remove it, slide the knob to left, and then pull out the lamp cover.
Loosen the screw that holds the lamp, then pull out the lamp.
5.Reattach the lamp.
Place back the new lamp and tighten the screw.
Replace the lamp cover, slide the knob to right till the up arrow down arrow mark
matches, and then tighten the screw.
6.Reattach the Front Panel Cover securely.
ok
Feb 26, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 6 yr old Mitsubishi DLP WD-52327 does not fire up... When power is turned on tv makes a noise like a small air compressor for a few seconds and then stops after about 1 minute it does it...
Oct 23, 2010 | Televison & Video
Whow to replace lamp on tv sony kdf-e60a20
Follow this procedure to replace the lamp:
1. Turn off the power on the main unit. Wait several minutes, then unplug
the power cord.
2. Wait at least 30 minutes after unplugging the power cord to allow the
lamp to cool down before replacing it. To avoid being burned, do not
touch the lamp receptacle once the lamp has been removed.
3. Take the new lamp out of the box.
Do not touch the glass portion of the new lamp.
✍ Do not shake the lamp. Vibration can damage the lamp or shorten
its life.
✍ Avoid touching the front glass of a new lamp or the glass of the
lamp receptacle. This may reduce picture quality or lamp life.
4. Loosen the screws on the rear side panel.
5. Remove the front panel.
6. Pull out the lamp.
Loosen the right screw on the cover with a coin or similar object.
Remove the screw from the lamp cover. Pull down the cover toward you.
Unscrew the lamp and pull out the lamp horizontally.
✍ The lamp is very hot immediately after use. Never touch the glass
portion of the lamp or the surrounding parts.
✍ After it has cooled, place the used lamp into the empty box of the
replacement lamp. Never put the used lamp into a plastic bag.
7. Place the new lamp into its place, then tighten the screw.
Mount the new lamp securely. Failure to mount correctly may cause a
fire or the screen to go dark.
Push the cover back on. Make sure that the hole on the cover aligns with
the hole on the unit. Reattach the lamp cover by tightening the screw.
✍ If the lamp cover screw is inserted incorrectly, the lamp may not
operate properly. In such a case, remove the screw, insert it
correctly and then tighten the screw completely
✍ If the lamp cover is not reattached securely, the self-diagnostic
function may be triggered and the POWER indicator flashes three
times
8. Reattach the front panel securely.
9. Tightly screw the side panel in its place.
That is it. Thank you.
Nov 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
KP57WV600 SCREEN TURNS GREEN THEN BLANK
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Problems turning my tv on, need to try several times
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
May 30, 2006 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
