Question about Philips Magnavox DVD/VCR Dual Player
My wr10d6 won't format or finalize, show error on screen
How to fix hdd format error?
on the menu screen push the "show other" option then scroll down "manage media" scroll down you can see media format in this menu, push this option there will show two options 1, HDD 2nd one is memory card here you select the HDD the screen will show "Format?" All data will be deleted. here you give "yes" another dialogue will appear "are you sure?" here you give yes, finally will show executing then press ok.
Jan 05, 2016 | Sony Handycam DCR-SR100 Camcorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Hi i want to format my compaq dq61 when i format my laptot it show me a blue screen error
You have to tell me whats the error code it shows on the blue screen so that I can help you resolve your problem.
Dec 10, 2010 | Computers & Internet
"format error" message
Reinsert memory card in camera and try to format it. If that does not help then check with new memory card as old memory card could be defective.
Thanks.
Mar 03, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Screen shows flash error to format
you should reinstall the firmware in the mp3 player
to do that you can go on the mp3 manufacture's website click on support and look for the appropriate firmware that fit your model number
once it's download
plug your mp3 to your pc and then run the firmware updater
you should be able to use your mp3
good luck
Jun 19, 2009 | GPX MW8847DT MP3 Player
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
Jul 11, 2007 | Samsung VP-DC161 DVD Camcorder
Player shuts itself off
Obvious stuff first. Check battery. Make sure the spring is making contact. Seeing as you are getting some power I would say thats not an issue. Connect it to a PC and make sure it has songs of the correct format. WMA and MP3. If its not a matter of incorrect file formats, it would be an internal problem. Possibly a short somewhere on the board. I am not sure as to the ease of repair on these players. SO I would look at sending it to the manufacturer.
May 30, 2006 | SanDisk Sansa m230 MP3 Player
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Philips Magnavox DVD/VCR Dual Player Logo
15 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
