Question about Maytag MER8770WS Stainless Steel Electric Range
OVEN DOESNT WORK
BRIOLER WORKS
  • Maytag Master
  • 3,382 Answers
I am not familiar with this unit but It could probably be one of two things. The broiler is the top element, since it gets hot you have enough energy. The bottom element could have failed. Carefully check the voltage on the two terminals on the heating element. There should be ~240 +- 20% volts. If you have that the element needs to be replaced. If not then it could be a bad control, or wireing.
Posted on Apr 29, 2014
GE JGBP33 gas oven will not light. Burners and brioler will light. When trying to ignite oven, igniter will not glow, and I see no change in voltage accross igniter contacts. What's next step to...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 27, 2011 | GE Ovens
When i trun on my stove the brioler does not go on
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Jan 15, 2011 | Kitchen Ranges
I have not so new Kenmore 790 gas range oven. The gas range and brioler work but the oven won't heat up. Suggestions?
I have the same oven and the same thing happened to me. I had to change out the heating element to Ignite the lower baking part. Trying to change it out is another story. I used metal snips to "open" the rear part to change it out. I was not ready to take apart the whole oven. The Part cost about 75$ from a part store, and the connections are easy. Hope this helped.
Aug 12, 2010 | Kenmore Ovens
Burners and broiler work, but oven doesn't
If the broiler is working then the element is good. The T-stat controls the oven temp. Have you checked it?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 03, 2009 | GE Spectra JGBP35 Gas Kitchen Range
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Dec 20, 2008 | GE JGBP33SEHSS Stainless Steel Gas Kitchen...
Viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Nov 25, 2008 | Viking VGIC305-4B Gas Kitchen Range
Oven wan work
make of stove .. digital or standard controls .. may not even be the oven ovens are 220 volts 110 works stove top other 110 works oven
Aug 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag MER8770WS Stainless Steel Electric Range Logo
41 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
