Question about Boating
Evinrude ficht problems - Boating
  • Lewis Meyer
    Lewis Meyer Apr 22, 2014
    Hi Jim Stead, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Jim Stead
    Jim Stead Apr 23, 2014
    We got the problem resolved, it was the power relay box. replaced it and up and running.
3 Suggested Answers
  • 86 Answers
SOURCE: Evinrude gives me a 30 sec. beep telling me I have no oil...
Disconnect the oil injection and mix your fuel. There are alot of problems with the Ficht systems.
Posted on Aug 06, 2009
goldbill
  • 184 Answers
SOURCE: I have a Evinrude Ficht 135 that Runs Ok but won't go in to gear, forward or reverse. Any ideas?
Disconnect the shift cable and see if the problem is with the shift box or the lower unit. If the lower, remove the bottom plug and look for water or metal where there should be clean oil.
If the shift box, take to the marina- they were a bear. Even just for cables.
Posted on Jul 23, 2012
My Evinrude Ficht 200 fuel injected, while running above 200 RPM has no problems but when idling the no oil alarm goes off and there is plenty of oil in the tank.
Its the oil sensor in the oil tank...does the oil line bulb stay pumped tight? If not. you need to do some investigating...or replace the bulb and line..
Jun 21, 2017 | Cars & Trucks
115hp evinrude ficht outboard wont start
blocked jets in the carby or problem injectors
Jul 04, 2016 | Boating
115hp evinrude ficht 2000 modelover wont start,
another ecu is less than a new motor . owners choice .
Jun 16, 2016 | Boating
Jun 17, 2012 | Light Boating
Starting motor binding/grinding
I will try to help. As you describe the problem I wonder if the starter gear is not cut deep enough to give clearance on the flywheel or the end bushing is too short. A short bushing would allow the gear to travel too far on the starter shaft and smack the flywheel.
Also the flywheel position would change if your particular motor has thrust washers on the crankshaft.
You may not know if anyone milled the starter case or motor. Maybe if you ground off the tip of the bolts it would help.
Apr 14, 2010 | Boating
Ficht wont start cold,will with a jumper box,what
Check the voltage on the pink wire on the starter selonoid. Should have at least 10 volts while cranking, if voltage drops below 10V change the batteries, I had the same problem.
Jan 06, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
Boating Logo
69 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
