Question about Koolertron For MG7 & MG ZT 2001 2002 2003 2004 2005 & Rover 75 / Indash Car DVD Player with GPS Navigation System and Digital Touchscreen and Bluetooth iPod Control Free Map
How to top up a mg hydragas suspension
My right side of my mg sports car is lower than the left side..ive just fitted new shocks...
    Scholar:
    New Friend:
  • 139 Answers
Are these air shocks? computer controlled? shocks or struts?
Posted on Apr 22, 2014
HOW DO YOU REMOVE THE SUPPORT TO FRAME BOLT ON THE REAR SUPPORT ASSEMBLY ON A PONTIAC TORRENT
Shock Absorber Replacement
Removal Procedure
Raise and support the vehicle. Refer to Vehicle Lifting
Remove the lower shock bolt.
For right side only, remove splash shield.
Remove the upper shock bolt.
Remove the shock from the vehicle.
Installation Procedure
Install the shock to the vehicle.
Notice: Refer to Fastener Notice in Service Precautions.
Install the upper shock bolt.
Tighten the bolt to 110 Nm (81 ft. Lbs.).
For right side only, install splash shield
Install the lower shock bolt.
Lower the vehicle.
For complete step by step guide with diagrams click the link below:
http://carrepairworld.blogspot.com/2016/06/how-to-remove-rear-suspension-on-2006.html
This will help.
Thanks
Jun 02, 2016 | 2006 Pontiac Torrent
Rebuilt front suspension. Now camber is WAY out. Everything looks right except shocks don't fit. Considering extra long camber adjustment bolts. Any advice appreciated
do not consider any long camber bolts as that is not fixing the fault for camber to be so far one of the control arms has been fitted incorrectly or in the wrong place
is the upper control arm on the right side of the mount on the chassis
is the lower control arm on the top
The car is manufactured correctly so check for collision damage that is placing the control arm positions so far out
best is to buy a workshop manual and study the set up for the suspension
rest assured that buying something to fix a fault that should not be there to start with is a futile exercise and a waste of money
for camber to be way out the wheels will be leaning way in at the top or way out at the top as that is what camber is
Nov 07, 2015 | Cars & Trucks
How to adjust height on rear springs
adjusting the spring tension makes the ride harder and mite hold you up slightly ! is the adjuster on the top of the shock and rotates by hand coz thats the oil reaction responce , or is it below the spring which you need a tool to adjust ? if suspension is nearly full compressed after all these then fit longer shocks ! Dial a ride air shocks are good as you can select the height , not cheep though ! P...
Dec 21, 2013 | 1987 Honda VT 1100 C Shadow
Stop car too low
first,I would like to ask you if you've had your suspension,shocks,and tire air pressure checked for irregularities;second, do the weight differences between the dredominating driver and right side passenger(s) differ significantly enough to produce consistant weight burden on passenger side suspension,or shocks-less than on the driver's side of your vehicle? If any of the above issues or mechanical irregularities exist,then those are most likely the reasons for your vehicle being lower on right than on left.have a mechanic thoroughly check the suspension for wear,damage to components,and /or bent parts,and if all is well, and those possible components do not need need replacing,then the next area of concern would likely be shock obsorbers,and if those do not need replacing then the problem may be that the vehicle's frame is bent or broken -depending on the type of frame your vehicle has..Process of elimination,while troubleshooting likely areas of concern may enable you to find cost effective,timely solutions to any vehicular problems. Best of luck.Steve Smith
Jul 11, 2012 | 2003 Mercedes-Benz E-Class
My mitsubishi l200 is leaning to one side. What
my mitsubishi pajero sport is leaning bad on the left hand side.what could be the problem???
Feb 10, 2010 | Mitsubishi Pickup Cars & Trucks
Left front suspension squeaking badly on 2000 Ford Explorer XLS. Is there a grease point for the A arms or do I need new struts/shocks?
If the boots are ripped on your lower ball joints you will need to replace them, rain water has washed away the factory lubricant they have no grease fitting from the factory. Replacements will come with grease fittings. Tie rod ends can also be the source of the noise, same deal no factory fittings. VERY COMMON PROBLEM.
Sep 27, 2009 | 2000 Ford Explorer
Do kia sedona have rear shocks or air suspennsion?
all suspension systems has shocks, but some are free standing and some are part of a Mcpherson Strut assembly, your rear suspension has standard stand alone shocks, they are not air shocks.
Aug 04, 2009 | 2002 Kia Sedona
Car not level
1991 and newer lincolns come equoipped with an air ride suspension..... tri adding air to the shocks...you can use any aair punp to do so.
Mar 17, 2009 | 1995 Lincoln Continental
I need to know how to get to the rear suspension (tower)
i don't think you have to do any repairs from the top end. I will list most fromFord shop manual. Please rate as Fixya if this answers your questions. Please report back. Good luck.
Section 04-02: Suspension and Wheel Hubs, Rear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual
REMOVAL AND INSTALLATION Spring Rear
Removal
  1. Position a hoist under the rear axle housing, and raise the vehicle. Refer to Section 00-02 . Place jackstands under frame side rails.
  1. Remove rear stabilizer bar as outlined.
  1. Disconnect the lower studs of the two shock absorbers from the mounting brackets on the rear axle assembly .
  1. Unsnap the RH parking brake rear cable and conduit (2A635) from RH upper arm retainer before lowering the rear axle assembly .
  1. Lower the hoist and axle housing until the rear springs are released.
  1. Remove rear spring and rear spring center mounting insulators (5741) from vehicle.
Shock Absorber Removal
Raise the vehicle on a hoist. 1. To assist in removing the upper attachment on shock absorbers using a plastic dust tube, place an open end wrench on the hex stamped into the dust tube's metal cap. For shock absorbers with a steel dust tube, simply grasp the tube to prevent stud rotation when loosening the retaining nut.
  1. Remove the shock absorber retaining nut, washer, and insulator assembly from the stud on the upper side of the frame. Discard nut. Compress the shock absorber to clear the hole in the frame, and remove the inner insulator and washer from the upper retaining stud.
  2. Remove the self-locking retaining nut, and disconnect the shock absorber lower stud from the mounting bracket on the rear axle tube.
  3. Perform Shock Absorber Checks. Refer to Section 04-00 to determine shock absorbers performance.
Installation
  1. Properly prime the new shock absorber . Refer to Section 04-00 , Shock Absorber Checks.
  1. Place the inner washer and rear spring insulator (5536) on the upper retaining stud, and position the shock absorber so that the upper retaining stud enters the hole in the frame. While holding the shock absorber in this position, install a new rear spring insulator , washer and nut assembly on the upper side of the upper frame. Be sure to seat the rear spring insulator in the frame attaching hole. Tighten nut to 34-46 Nm (25-34 lb-ft).
  1. Extend the shock absorber , and place the lower stud in the mounting bracket hole on the rear axle assembly housing. Install a new self-locking retaining nut. Tighten nut to 76.5-103.5 Nm (56-76 lb-ft).
  1. Lower vehicle.
Arm Lower
Removal
Refer to the illustration in Description and Operation. NOTE: To improve rear axle assembly noise and vibration concerns, the rear suspension should be fastened to the frame and rear axle assembly at the curb height position.
NOTE: If one rear suspension lower arm requires replacement, also replace the opposite rear suspension lower arm .
sra~us~en~file=ani_caut.gif~gen~ref.gif WARNING: TURN REAR SUSPENSION LEVELER COMPRESSOR SWITCH OFF (IF SO EQUIPPED).
NOTE: If both rear suspension arm and bushings and both rear suspension lower arms are to be removed at the same time, remove both rear springs as outlined under Rear Spring Removal. For air spring removal, refer to Section 04-05 .
  1. Mark rear suspension shock absorber relative to protective sleeve with the vehicle in a static, level ground condition.
  1. Raise the vehicle on a hoist, and place jackstands under the rear axle assembly . Refer to Section 00-02 .
  1. Lower the hoist until the shock absorbers are fully extended to relieve rear spring pressure.
  1. Support rear axle assembly under differential pinion nose as well as under rear axle assembly .
  1. Remove and discard the lower arm pivot bolt and nut from the axle bracket. Then, disengage the rear suspension lower arm from the bracket.
  1. Remove and discard the pivot bolt and nut from the frame bracket, and remove the rear suspension lower arm .
Upper
Removal
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Suspension Bushing Service Set T79P-5638-A1, A2 and A5 Rear Axle Control Arm Bushing Tools T86P-5638-AH
sra~us~en~file=ani_caut.gif~gen~ref.gif WARNING: TURN OFF REAR SUSPENSION LEVELER COMPRESSOR SWITCH (IF SO EQUIPPED).
  1. Raise the vehicle, and support the frame side rails with jackstands. Refer to Section 00-02 .
  2. Support the rear axle assembly .
  3. Lower the rear axle assembly , and support the rear axle assembly under differential pinion nose as well as under rear axle assembly .
  4. Unsnap parking brake rear cable and conduit from upper arm retainer.
  5. Remove and discard the nut and bolt retaining the rear suspension arm and bushing to the rear axle assembly housing. Disconnect the rear suspension arm and bushing from the housing.
  6. Remove and discard the nut and bolt that secures the rear suspension arm and bushing to the frame bracket, and remove the rear suspension arm and bushing . If upper arm rear bushing is to be replaced, use Suspension Bushing Service Set T79P-5638-A and Rear Axle Control Arm Bushing Tools T86P-5638-AH and the following procedure:
  7. Place the upper arm rear bushing remover tool in position, and pull bushing out. Using Suspension Bushing Service Set T79P-5638-A install bushing assembly into bushing ear of rear axle assembly.
Stabilizer Bar
Removal
  1. Raise vehicle on hoist, and place jackstands under the frame side rails. Refer to Section 00-02 .
  1. Lower the hoist and rear axle assembly housing until the shock absorbers are fully extended.
  1. Disconnect rear stabilizer bars from rear stabilizer bar link and bushing (5C488) . Remove bolts and stabilizer bar bracket (5486) retaining rear stabilizer bar to rear axle assembly .
Mar 05, 2009 | 1994 Lincoln Town Car
Koolertron For MG7 & MG ZT 2001 2002 2003 2004 2005 & Rover 75 / Indash Car DVD Player with GPS Navigation System and Digital Touchscreen and Bluetooth iPod Control Free Map Logo
103 people viewed this question
Top Koolertron Video Cameras Experts
hangie
Level 1 Expert
 Mikey
Mikey
Are you a Koolertron Video Camera Expert? Answer questions, earn points and help others
