Question about Samsung UN22D5003 22-Inch 1080p Clear Motion Rate 120 LED HDTV Black
Missing screws that connects from the base to the back of T.V.Samsung UN22D5003 22-Inch
  • Lewis Meyer
    Lewis Meyer Apr 22, 2014
    Hi Luis Torres, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Westinghouse tv
There is very little if any tactile feedback from most flat panels. Most also have more than six screws unless this is a very small <19 inch set. Look very carefully for a missed screw. In my experience the backs come off easily. Some sets require the mounting screw receivers be removed. They are usually removed with a flathead screwdriver.
Jul 08, 2016 | Westinghouse W4207 42 in. HD-Ready LCD TV
I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
1 PointsProblem with Toshiba TV Accessories I lost my screws that goes to my tv stand the base I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
Nov 02, 2011 | Toshiba Televison & Video
I want to wall mount a FX2490HD and cannot remove the base I have remove the screw form the back but the base will not move
Hi, there are two screws underneath the legs of the stand and one other screw to hold the attachment that the legs connect to. If you have removed all three screws then try swiveling the legs.
Feb 12, 2011 | Samsung Televison & Video
How do we remove the base stand from the lcd-32xr8da so we can wall mount it
There are 4 screws connecting the base to the tv on the 40xbr. didnt check to see if its the same with the 32 inch. the base connects to the tv (on the bigger one) via two prongs both with 2 screws in it, look for the screws and you're all set.
Feb 04, 2010 | Sanyo Televison & Video
My banner scope in 4 to 12 wii not hold zero
I'd start by looking at the mounting bases.
First tighten the scope ring screws to 25 inch pounds, then loosen and remove the rings from the base(s) while still attached to the scope.
Back out the base screws one at a time, apply low strength thread locking compound and tighten each to 25 inch pounds.
Remount the rings/scope to the bases tightening till snug but not overly tight and sight-in the rifle.
Hope this helps, Mark the Gunsmith
Nov 14, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
There are no bolts to mount my Samsung Series 6 to my TV Stand
YES TAKE THE SMALL BOLTS WITH YOU AND GET LONGER ONES
Aug 24, 2009 | Samsung Televison & Video
How do I remove the back panel from a samsung LN-408D? I have removed all of the screws, but the panel doesn't seem to come off.
Samsung LCD TVs has 12-16 screws that need to be removed before taking back off.
Dont forget the screws that hold the connection panel (SCART, HDMI, etc) and the bottom screws that hold the stand. These are screws i missed when i first opened my Samsung TV.
Good luck !
Jun 29, 2009 | Samsung LN-R408D 40 in. LCD HDTV
Removal of eMachine M6410 optical drive
There are two small screws that the monitor cable would screw into, these have to be removed (7mm i believe) to be able to remove the base. The optical drive will typically pull out of the side after a screw has been removed and latch has been opened. I wouldn't go as far as removing the entire base.
Dec 08, 2008 | E-Machines M5305 Notebook
We have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Nov 19, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Samsung UN22D5003 22-Inch 1080p Clear Motion Rate 120 LED HDTV Black Logo
23 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
