Question about Sanyo DP26746 26 in. LCD Television
How do you locate the TCon board on a Sanyo DP26648 TV
Where is the TCon board on this TV
taran_2005
  • 10515 Answers
SOURCE: How do I hook up a dell laptop to a 50
You can refer to 2 tutorials :-
http://www.techlore.com/article/10061/How-To-Connect-a-Computer-To-Your-TV/
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Thanks.
Posted on Jul 27, 2009
  • 3 Answers
SOURCE: On our Sanyo TV model DP26648, the picture runs
Pixal on Remote
Posted on Mar 11, 2010
  • 3 Answers
SOURCE: My Sanyo 26" LCD TV - model DP26648 has sound but only displays a
Turn off and on
diodeic
  • 1622 Answers
SOURCE: Sanyo Lcd sound good screen black. All voltages
The T-CON board is usually under a metal shield cover and sitting on the middle top section of the screen, you will see a very thin connector with VERY SMALL WIRE attached to it, be real careful when you try to remove this connector.
There is F1 fuse on the left side of the connector.
Check to see if you do have 12v on it and it is not blown.
if otherwise,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help to solve the problem...
Posted on Aug 23, 2011
SD Tech
  • 14553 Answers
SOURCE: how do I connect a playstation 3 to my sanyo tv DP26648
try it on another set first to see if game or the set is the issue.
Posted on Jun 17, 2012
How do I connect a playstation 3 to my sanyo tv DP26648
Jun 17, 2012 | Sanyo DP26648 LCD TV
What could cause a 27" Sanyo flat panel dp26648 to lose picture, but keep sound?
There are two reasons why your Sanyo DP26648 would has sound but no image and both are equally likely in our experience.
First, you may have a problem in the section of the power board that supplies the backlight module (called inverter) with 24V.
We've seen that several times and the problem is usually minimal - only electrolytic capacitors gone bad - and other times not so minimal.
We have a repair service for that power board and we may have some boards available too...check out at
http://www.coppelltvrepair.com/search?Q=DP26648+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Apr 04, 2012 | Sanyo DP26648 LCD TV
2008 Sanyo DP26648 has a black screen but has sound
Check its T'Con board. This is a common fault to all type of LCD TVs
Apr 02, 2012 | Sanyo DP26648-R 26 in. LCD TV
I have a sanyo DP26648, when it is turned on it goes to a blank white screen
Replace the main board. The guys at www.tvcircuitboards can assist in getting a replacement main board with warranty. Just hit the contact us button and leave a email with model number and symptom
Feb 20, 2012 | Sanyo DP26649 26 in. TV
Neither "solution" is a solution. Anyone actually
Your problem is the T-con board. This is gone bad/faulty. I would advice you to replace it with new T-con board and your unit will back to normal again. You may look for the replacement online. Try ebay.com or shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 16, 2011 | Sanyo DP26648-R 26 in. LCD TV
Looking for new or used main motherboard
Required main board for Sanyo DP26648 lcd tv is available in Shop Jimmy.com for $70
Click to view image of board, make sure your tv model is as shown in your question headings.
Thanks.
Oct 23, 2010 | Sanyo DP26648 LCD TV
How do I hook up a dell laptop to a 50" Sanyo Dp26648 LCD TV
Thanks.
Jul 27, 2009 | Sanyo DP26648 LCD TV
Sanyo DP26746 26 in. LCD Television Logo
46 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
