Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Konica c253 prints black bakground with white text
  • Konica Minolta Master
  • 6,161 Answers
Check setting such as invert copy
Posted on Dec 30, 2015
Kevin Hayes
  • 167 Answers
SOURCE: C253 Bizhub Konica Minolta Printer
Try pinging the printer from a computer.
It sounds like a hardware issue, have you checked the network plugs?
Also, try checking if the assigned IP address is conflicting with something else that may have not been online for installation.
Posted on Feb 25, 2008
  • 158 Answers
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Posted on Nov 16, 2009
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Posted on Apr 07, 2010
Bizhubman
  • 108 Answers
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
Posted on May 19, 2010
All the copies and print outs are black colour. Why is this happening?
Have you check the gradation print out for each color in the service mode? Recommended that you do that. Does this happen in printing or copying? There is a difference. Any warning to replace certain parts? Check consumables what needs to be replaced? What does the demo page look like? Are the image units OEM? is the transfer belt OEM? Service mode + Counter, details, stop00 stop01, output, gradation pattern.
Oct 30, 2015 | Konica Minolta Bizhub C253 Copier
How do i clear error c4154
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Oct 17, 2015 | Konica Minolta Minolta Bizhub C253 Copier
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
PROCESS IN HOW TO CALIBRATE C253
utility /counter, details, stop 00 stop 01,(SERVICE MODE) Image processing adjustment select all colors run twice ensure the image units are toned up for the gradation adj. Now run stabilization once. Now you will run the following three times (Gradation, Resolution, and compression). each. you will press start machine will run and print out a chart place the chart on the big glass do not use the document feeder use your best paper no color paper!!!!! ensure the black square are up against the scale on the left side you can use 11 x 17 or 8.5 x 11 paper 11 x 17 will give extra color strip not used 8.5 x 11 must be landscape. press start. In the end you should have 12 print outs 3 from each process.
Gradation, Resolution, and compression. once done print out a demo page in user mode check it out.
Feb 23, 2013 | Konica Minolta Bizhub C253 With Document...
Printing from Adobe Illustrator
Try to retarget work of your printer under your type of the used paper. Such parameters as density of the paper can have important importance. Try to print one and that document on miscellaneous type papers
Mar 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Problem Printing accurately colors from Corle Draw to Bizhub C252
The reddish greys are something a Fiery will correct, that is part of it's function. (GCR).
I would try turining colour management off, or rasterizing the file in Corel. I believe there is an option in the print window.
Have you tried making a PDF of the file and printing that?
Using the ICC profile could be a solution, but the Fiery is what is needed.
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
