Question about Troy Bilt Tb70ss Gas Trimmer
Pull string is to loose
How do I tighten up the pull string
    Scholar:
    New Friend:
  • 139 Answers
As big as a pain it is. you have to unscrew the pull mount and rewind it outside the wheel. they tend to loop over the top and this happens when you pull hard and let it snap back by letting it go. cord loops over the top. next time you pull it pulls it over the top and each time you do it, it becomes looser.
Posted on Apr 22, 2014
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
I cant pull the string to start the mower
pull plug out tie up bail handle see if you can turn engine over by hand if you can pull hard on rope it has jamed if not .move check for locked up mover add oil to cylinder for it to turn over till its free my have to take recoil off to do this if the reciol starter pawls or lock in
Aug 30, 2014 | Garden
Pull string
you might have you coil set to close to the flywheel and the coil is not letting the flywheel spin like it is suposto sotheir for you string id to tin\ght when you hace the hood on so reagap the coil and sett it a little farther back from the flywheel by not to far back
May 14, 2013 | Mtd 22" Yard Machine Push Mower
Guitar tuning peg seems like it might be broken it will tighten the string to a certain point then it clicks and its completely loose again...I'm new to guitar so I don't know If this is normal
It seems like you wound and tightened your string on the tuning peg loosley. Try wounding the string at least 4-5 times around the peg after you pass the wire though it and then after winding pass it through the hole again. Tighten well.
If that doesn't work your peg might be broken, but looking at it on the video seems that it's not, even though you can't see it clearly.
Try tightening the screws on the peg, since there's a lot of tension on the highest string and it might cause the peg to click back because the tension is too high and it's loose.
Jan 30, 2013 | Music
How to change the strings onthe epiphone professional deluxe mandolin
You can slide the silver plate straight back by gently pushing it from the top with your fingers. Once it slides off you will then be able to see the hooks that you put the new strings on (loop end strings). Once strings are tightened, you slide the cover back on the same way you slid it off. There is a small piece of felt glued to the cover. Be careful not to knock it loose when you are putting the cover on.
One other tip, change one string at a time instead of pulling all of them off at once. The bridge will come loose if you take all the strings off at once (it is not glued to the mandolin).
Feb 17, 2012 | Epiphone MM-50E Professional Mandolin
I am re-stringing my Fender 140sce and every time I begin to tune a new string up, the peg pops up. Do I keep pressure on it to try and keep it in place until it is fully in tune, or is this out of the...
It is a little tricky, but you have to kind of pre-form the ball end of the string so it tucks under the ledge of the hole it goes into. Then put peg in and as you do pull up on the string slightly so the pre-formed ball end is caught under the ledge. Make sure the slot is toward the neck direction and the string seats in it, Also once the string is seated, kind of preform the string over the edge of the hole as the string is started to be tightened.
May 28, 2011 | Fender CD140sce Acoustic Electric Guitar
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
The pull cord for starting the cutter has detatched
normaly there is 4 bolts holding the cover on take them out and the pull clutch in under there,,, put the string back in the cover and tighten the clutch up first so it pulls the strin in when you let it go,,,tiy a good knot in the pull start string or you will just pull it out again!
Jul 01, 2010 | Ryobi Garden
Mackie 1604 vlz3 loose knobs
If these are the rotary knobs, pull them off and compare the shaft to one htat is tight. Sometimes it is a split shaft and you can GENTLY bend them out the tiniest amount to tighten the knobs.
If the shafts are plastic, try putting a few strands of thin string across the shaft before putting the knob on.
the knobs pull off but take a bit of forcee to do so.
IF IT SEEMS that the shaft itself is looser than others, best leave it alone. Replacing a pot on these takes a lot of work... MANY knobs must be pulled off and the case opened and at least a section of the board with the pots removed to access the pots.
Jan 12, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
49cc kids ATV trouble shooting
in order to tighten your chain you can take a link off which would involve using a grinder, if you dont have one than go to an atv store and ask them to do it. theres a clip on the chain which holds it togther, remove the clip without damaging it than just pop the link off. that will take the chain off. i dont know what type off atv you have so there are probably bolts that hold pull the back end to tighten the chain look for those and if you can find them than tighten them.
for your engine do an oil change and drain out the carborator. if you need more help let me know.
Jun 24, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Troy Bilt Tb70ss Gas Trimmer Logo
51 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
