Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator door keeps opening - Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
  • 884 Answers
Check the hinges are tight and seal in correct place to seal and stick. make sure no shelves are out of position stopping the door from closing properly, and lose some weight from the door if you keep lots of heavy bottles in it.
Posted on Apr 22, 2014
Why is there ice buildup behind the pantry drawer?
Hello
This is caused when the refrigerator door is repeatedly opened and closed thereby allowing excess air to enter or if there is a problem with the door seal of your refrigerator.
To get rid of the ice you have to defrost your refrigerator regularly or once the ice is 3mm thick.
Permanent solution will be to not to keep your refrigerator door open always and you should also check your door seal
Jun 04, 2015 | Refrigerators
My freezer works but my refrigerator part is not cold
The is normally a duct between fridge and freezer which can over ice can take 3or 4 days to defrost with both doors open and unplugged.
Jan 14, 2014 | Refrigerators
The top freezer door opens slightly and then reseals whenever the lower refrigerator door is closed
The lower section is connected to the top section through a common opening in the freezer floor. Shutting the bottom, being it is larger, will force air to open the top door. I installed a roller for a cabinet on top of my fridge to keep the door from pumping open. It is used to keep children out of cabinets. It is a roller wheel mounted on a spring loaded arm. It keeps the freezer shut until we open it. Some times the pumping action will force the door open enough it will not shut and things get soft. Hope this Helps Fix Ya up.
Jun 27, 2011 | GE PTC22SBMR Top Freezer Refrigerator
Our GE upright freezer door keeps opening on its own! Our food is starting to melt and the manual only talks about tightening the refrigerator door. What should i do?
Your refrigerator is leaning forward to far and you need to adjust the front legs so that it is slightly leaning back. This is why the doors are opening as they work by gravity. On the bottom left and right front corners of your refrigerator you should round pads with threaded legs screwed it the bottom of your refrigerator. You need to lean the unit back and adjust these out to raise the front of your refrigerator until the doors when opened will slowly shut on its own. A level comes in handy for leveling also.
Oct 09, 2009 | GE Refrigerators
Refrigerator door keeps popping open
Level refrigerator with front 1/4-1/2 bubble too high in front.
Mar 08, 2009 | Refrigerators
Moisture
Are the air vents blocked in the refrigerator? Remove any
objects from in front of the air vents. See "Ensuring Proper Air
Circulation" for the location of air vents.
Are the door(s) opened often? To avoid humidity buildup,
try to get everything you need out of the refrigerator at once,
keep food organized so it is easy to find, and close the door
as soon as the food is removed. When the door is opened,
humidity from the room air enters the refrigerator. The more
often the door is opened, the faster humidity builds up,
especially when the room itself is very humid.
Feb 19, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Magic Chef Refrigerator door flys open
Sounds like you have the unit out of level front to back leaning towards the back. Try leveling or just tilted a little with the top leaning just a little toward you. This should keep it from flying all the way around.
Jan 05, 2009 | Magic Chef CTB1922 Top Freezer...
Kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Dec 21, 2008 | KitchenAid Architect KBFA20ERSS Stainless...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
