Question about HP Office Equipment & Supplies
HP LaserJet 3030 Scan application does not work.
I get the same message as the other poster. I think that the problem may have something to do with the order the software for two scanners was installed in.. Summary: Was using LaserJet 3030 parallel interface and a IEEE-1394 scanner. Switching LaserJet 3030 to USB required removing HP software and ''hp LaserJet TWAIN 1.0 (32-32)'', Scan, and Send fax don't work. Here are the details. I am running Windows XP Professional with Service Pack 3. I had installed the LaserJet 3030 using the parallel interface and then an Epson Perfection 3200. Things were working fine. I was also able to print on a remotely connected LaserJet 3030. I had another machine using the same Epson scanner and LaserJet 3030 through the respective USB interfaces, with this machine using the LaserJet 3030 parallel interface and Epson IEEE-1394a interface. I disconnected the parallel interface and connected the LaserJet 3030 USB interface. The software didn't see a new device, so I removed all LaserJet 3030 printers (local and remote) and fax device, removed all other traces of HP and installed the software. (Actually, the guy from HP did software stuff remotely.) Now when I try to Scan or use Paint Shop Pro with source ''hp LaserJet 3030 TWAIN (32-32)'' I get: 1. first, the normal dialogue and the startup window that has the ''hp invent'' logo, a drawing of a scanner, and the heading ''HP Scanning'' 2. then an error popup window with title ''hp scanning'' that looks something like:
(X) Sorry, could not find required user interface files.
(Please reinstall scanning software.)
[OK]
3. If I wait long enough, I get a popup window with title ''Error'' that looks about like this:
/! Unable to communicate with HP scanning software. Please verify that it has been installed and is working properly. If
this problem persists, please shut down your application and try again.
[OK]
The other machine works with both scanners on USB.
2 Suggested Answers
  • 3 Answers
SOURCE: HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Posted on Jan 10, 2009
I have a hp LaserJet 3030 and I have misplaced the disk and now I cannot scan. When I press scan to it says - not setup in computer and when I press start scan it says - Waiting for pc. Please help
Access the manufacturer's web-site: http://support.hp.com
Enter '3030' and select your printer.
Click 'Software Downloads'.
Select your Operating System (Mac? Vista? 7?)
Download the device-driver.
Install the device-driver.
Scan.
Jan 23, 2011 | HP LaserJet 3030 All-In-One Printer
Can i feed 8 1/2 inch x 11 inch poster weight paper into my 3030?
Poster weight is too heavy for this machine, when paper is picked up it has to curl around the rollers in the back and do a complete turn-around. poster weight will just jam at the first turn.
Aug 07, 2009 | HP LaserJet 3030 All-In-One Printer
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
Hp scanner 3030
i have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
Aug 31, 2008 | HP LaserJet 3030 All-In-One Printer
Want to download drive for a scanner hp laserjet 3030 to my laptop
Hi want to find out how to scan from my hp laserjet 3030 all in one printer, fax, copier and scanner please.
Aug 25, 2008 | HP LaserJet 3380 All-In-One Printer
Hp laserjet 3030 problem
Remove and replace the side covers again. One of them (I think right) has a tab that pushes an interconnect lever that if not reinstalled correctly or carefully will cause this error.
Here's the HP Service manual to walk you through it again.
http://www.feedroller.com/Store/Service%20Manual/LaserJet%203015%203020%203030%20all%20in%201%20sm%20MFP.pdf
Hope this helps you.
Aug 01, 2008 | HP LaserJet 3030 All-In-One Printer
HP Laserjet 3030
Reinstal the printer ......complet reinstal.....
May 04, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 Message: Scanning error cannot connect
I had the same problem on XP and Vista and it turns out that if your don't have the HP Toolbox Running/starting up with pc this caused my problem. Once I lunched it to startup with I am able to scan using the Scan To Button on my Scanner.
-Cepedare
Apr 04, 2008 | HP LaserJet 3030 All-In-One Printer
1,780 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
