Question about Whirlpool Washing Machines
WASHING MACHINE TAKING TOO LONG - Whirlpool Washing Machines
The washing machine is taking longer time
You can check that pump filter which is behind the base plinth, also check that the water entering the machine is at a reasonable pressure. If the machine is taking a longer time to wash and both inlet and the outlet of water is ok, it is more than likely a wash side heater fault. Basically, you set, for example. a 40 degree cycle, the heater does not operate and the water never reaches the required temp, the machine ventually times out on the heat phase and then moves on to the rinses or aborts to the end of the cycle.
Nov 26, 2011 | Bosch Washing Machines
Maching not taking in water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 26, 2011 | Siemens WXL132GB Front Load Washer
Machine does not taking water
heatman101
Apr 24, 2011 | Washing Machines
Not taking in water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Jan 15, 2011 | Washing Machines
Not working no taking water
heatman101
Oct 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washing Machines Fp60 water is not taking in by the cold valve
heatman101
Sep 18, 2010 | Washing Machines
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
My Washing machine is not taking water from PUMP
Do you mean that there is no water flowing into washer when your turn it on. If that is what you mean it is probably you intake solenoid is bad.
Aug 07, 2009 | Samsung WF328AAW Front Load Washer
Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Oct 09, 2008 | Washing Machines
Washing machine keeps taking water in even after programme has stopped
poss moisture on your control module causing tracking . unplug your machine from the mains and take the back panel off, you can try blowdrying the module down in the bottom left hand corner or you can take it off (noting where all the leads go to),get an old toothbrush and clean the solered side around the bottom of the board failing that you will most probably have to change it
Jul 07, 2007 | Indesit WA 115 Front Load Washer
Washing Machines Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
