Question about Whirlpool Refrigerators
Whirlpool gold model #gb2fhdxwq it is a bottom freezer, forms ice on the bottom of the freezer
Ice forms on bottom of freezer
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
TheMobilian
  • 8220 Answers
SOURCE: Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
Posted on Mar 01, 2009
  • 219 Answers
SOURCE: water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
Posted on Mar 19, 2009
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
I have a maytag bottom freezer refrigerator model# MFF2558VB3 that is forming a sheet of ice on the bottom.
Type in the search engine on your computer Refrigerator Repair-Ice in the freezer- Whirlpool, Maytag, Kenmore
Do that and it should give you your answer.
Jun 19, 2017 | Maytag Refrigerators
My whirlpool gold refrigerator will not cool. Only the bottom freezer works
Sometimes when the freezer door is cracked open a bit for too long, ice forms inside around the vent. I believe the fridge is cooled by the freezer air coming through that vent. Defrost the freezer completely, about 36 hours, and wipe it around till it is clean and dry. Then turn it back on and just wait... My Maytag fixed itself that way, and it took a few days to get cool to temp again..... Good Luck!
Feb 03, 2016 | Whirlpool Refrigerators
GB2FHDXWQ top of refrigerator to warm, in crisper area to cold
I realize this question was posted on 11-17-2015 if you still need help please answer the question so I may help you. Look into the freezer on the back wall to see if there is a layer of ice forming. Can you tell me what you see?
APPLIANCE 911
Nov 17, 2015 | Whirlpool Refrigerators
Ice forming at bottom of freezer
I had a problem with Ice forming in the bottom of my freezer on my whirlpool side by side freezer-refrigerator. Turn out to be a plugged drain in the bottom of the freezer. That drain goes into a tray under the whole unit. During Defrost, condensate drops from the contents of the freezer on to the bottom of the freezer and goes through a drain tube to a pan underneath. Should that drain tube become plug and the water is left standing in the bottom of the freezer, it will turn back to ice after the defrost cycle is over. Once the drain tube is clean out, the problem goes away.
Oct 20, 2014 | Whirlpool Refrigerators
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
I have a 3 door Whirlpool Gold fridge. The bottom
ACTUALL FREEZER TEMPATURE MAY BE ABOVE 17 DEGREES. THEN THE ICE MAKER WILL NOT WORK. OR MOISTURE GOT IN TO THE HEAD OF THE ICE MAKER AND FROZE THE GEAR.
Apr 24, 2010 | Refrigerators
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Water buildup in the fridge, dripping in from the freezer
This could be a bad thermostat. If your thermostat never closes it's swith then the defrost element never comes on and you get the problem you are having. Easy fix. Do you know where your timer is and can you retate it?
Jul 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
26 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
