Question about Seagate Computers & Internet
St3250310as hard disk failure is imminent - Seagate Computers & Internet
  • Seagate Master
  • 3,368 Answers
Believe it, get a new hard drive and copy files to it. You can use a drive copy program such as Reflect, they allow downloading a demo version that works.
Posted on Jan 07, 2017
  • 56 Answers
SOURCE: hard disk probleme
If you are still able to read from the drive, i would copy all of your important files off of it and replace with a new one.
Posted on Jan 29, 2008
  • 45 Answers
SOURCE: SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Posted on Jul 29, 2009
  • 3600 Answers
SOURCE: Got a Acer 5420 that won't boot
First before replaceing the drive try to start in safe mode, if you can start it in safe mode do so with network support and go to malyware bytes and download their software to remove the bugs you have on the computer run disk cleanup and disk defragment as well, this is caused by some of the bugs that have come out. If it indeed is the drive out your in trouble if you have not backed it up, but post here to let me know and I will help you if I can, also please rate me if this helped.
Posted on Aug 12, 2009
  • 17 Answers
SOURCE: get the message 'hard drive failure imminent
Have you tried turning off/on again your laptop?
If you did but still getting the same message am afraid you will have to replace the hard disk
Posted on Jan 04, 2010
  • 561 Answers
SOURCE: hard disk failure
Thank you for your query
From what you are describing something called SMART which resides on your motherboard has kicked in.
This little utillity will kick in just before your hard drive is about to fail, allowing you time to copy data across
I would not waste time, please copy your data as soon as possible and then replace your hard drive
I hope this has been useful
Posted on Mar 15, 2010
Hard disk failure
Check if your hard drive is still in warranty period so you could ask for replacement from the manufacturer. Otherwise, simply buy a new hard drive and move all your data from the old one to the new drive.
SMART always predicts correct hard drive status and probably this time, you need to change it ASAP.
Hope it helps!!
Dec 07, 2012 | Western Digital WD Scorpio Blue WD2500BEVT...
Imminent harddrive failure
Hard Disk about to fail This warning means the hard disk will fail sometime in the near future. You need to back up your data regularly before the hard disk fails or you will lose your data.
Oct 01, 2012 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
I have a imminent failure and when I press F1 then I start installing Windows the system doesn't detect my HDD. I have a bad sectors and I know it. But I can't solve it. Can you tell me more information...
The motherboard is quering the 'S.M.A.R.T.' status of the disk-drive,
and the disk-drive is reporting that it is about to "fail".
So, your motherboard is showing that "Imminent failure -- press F1 to ignore this alert" message.
Take your computer to a qualified technician, to see if it is "too late" to recover any files from your disk-drive, and/or to install a new disk-drive, and to install Windows.
Nov 09, 2010 | Hitachi 60GB Travelstar 5K160 Ultra...
I can not access my computer after imminent failure message
> imminent failure message ... cannot access
Bad luck that the 'imminent' failure was _SO_ soon followed by _complete_ failure.
Buy a new disk-drive. Disconnect the old disk-drive.
Install Windows to the new disk-drive.
Reconnect the old disk-drive, as a 'slave' disk-drive, and hope that you can access the files on it, even though you could no longer 'boot' Windows from it.
Oct 26, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
Get the message 'hard drive failure imminent
Jan 04, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
How to fixs this
The hard drive is going bad cause it can't read the sectors properly.
Either get a known good workng hard drive in the computer or a brand new one and restore the computer back to factory defaults.
Aug 19, 2009 | HP Pavilion a1700n PC Desktop
SMART Hard Drive detects imminent failure. Your hard disk drive is detecting an imminent failure. To ensure no data loss, backup contents and replace this hard disk
Jun 19, 2008 | Computers & Internet
Computers & Internet Logo
109 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
