Question about Refrigerators
How do i reset a Bosch fridge freezer after switching it off
Model No KGU32164GB102. I accidentally switched my fridge freezer off this morning and on switching it back on I get an alarm and now very low settings. How do I reset temperatures to the correct ones please.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 139 Answers
Usually have to wait about 15 minutes before turning it back on otherwise the compressor will reset itself on and off till you pull the plug out for 15 minutes
Hope this helps. God Bless :O)
Posted on Apr 22, 2014
Testimonial: "Sorry lewis but that doesn't help. Last time we did this Bosch told us to switch the fridge off again and leave the doors open overnight to defrost, then switch back on again and it will reset eventually. I did this last night and switched it back on this morning. I've come home tonight and one setting is 22 and the other 05. The 5 number needs to reach 18. Good job I didn't do a fridge shop today. No 24hr customer service available tonight like they promised as their system is down...."
  • 14 Answers
SOURCE: Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Posted on Jan 17, 2008
maklean
  • 1665 Answers
SOURCE: MIELE KFN8762SDED (SS/fridge/freezer)
Have a look at page 5 (KFN8767 Miele refrigerator) it may be similar. Exact model number didnt find.
http://www.miele.co.uk/Resources/OperatingInstructions/KFN%208767%20S%20ed-2.pdf
Posted on Sep 19, 2008
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Bosch cooler fridge who cools too much
In your case I will need to assume that your model is a typical refrigerator with a defrost control and these type have parts that are made up of the major parts for the auto defrost. Auto defrost has a most likely problem found in the timer or electronic defrost control. These are most times found inside the fresh food section and behind the temperature control panel in the photo below marked a E and in that photo it shows a defrost timer in lower arrow and a electronic defrost control in the upper arrow. The next most likely problem would be the defrost heater and defrost thermostat found in the rear of the freezer compartment. Sounds like the defrost system has failed. Most Brand models We are able to handle here in the USA but your model is made ih the UK and I have tried my best to Have your dealers provide me information about parts replacement. A refrigerator is a Refrigerator and that is a fact but your models is designed for your local voltage 220 volt at 50 cycles That is normal home voltage in most countries except th USA. Our voltage for an appliance is 120 volts at 60 cycles so all the electrical components ar different and made different for different countries. When I request parts or diagrams from the UK I am always rejected. Then given a local repair center to service the brand of appliance.
Posted on Sep 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
I have a LG fridge freezer that wont stop beeping any help would be greatful model number..GWB227WLQA
Most new style have a warning tone that door is open.
start by manually pushing any door switches ( interior lights should go out). If light stays on you have faulty switch.
Freezer with no light a little harder, but if you have meter and are able to get switch out you can test for continuity.
Not sure of voltage to switch so remove power to fridge while removing switch.
With power removed ( unplugged) you maybe able to remove switch and connect wires together with electrical tape. Plug unit back in see if alarm is off.
Remember if not comfortable with that process call service.
Sep 22, 2016 | LG Refrigerators
I have an iridium fridge, bottom freezer. The alarm keeps going off roughly every 8 hours. It can be silenced by pressing the temp select button.
Sounds like it is telling you that you need a service technician. It may be sensing low gas.
Before that though, check the grills on the compressor for fluff blockage. If you find any, vacuum it off.
Aug 14, 2016 | Fisher and Paykel Refrigerators
I have a GE Profile bottom freezer that door alarm will not stop. How do I fix it. I turned off the breaker for 30 minutes, and the alarm was silent when I powered back up, but the started to repeatedly...
Open freezer door. On top You will see 2 or 3 switches. Push all of them, if light in the freezer did not go off - you have bad door switch, if it did go off try same thing with fresh food door. Door switches do go bad once in a while on this fridges. Thanks
Mar 23, 2015 | GE Refrigerators
Can a Miele fridge freezer with both sections warm, fans working, be repaired?
You mean it's not an auto-defrost model? It should be, no older than it is.
Sep 05, 2014 | Refrigerators
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
I have a Bosch Classixx KGV28V01GB fridge freezer. I defrosted it as there was a bog built up of ice in the freezer. I switched the fridge freezer back on today and have noticed that the fridge is not...
it will take at least 48 hours for a large fridge freezer to settle down after a complete defrost,so leave it alone with the door shut,set at you favourite temp....
Jul 27, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch fridge frezer
gas is sealed for life....sounds like it is auto defrost mode.leave switched on. after a full manual defrost. for at least 24 hours to settle down keep door shut... then check. should reset itself.make sure all vents,drains are clean.
Feb 14, 2010 | Freezers
Refrigerators Logo
459 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
