Question about Thermador Pro Harmony PRD366EHU (Dual Fuel) Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Oven shuts off
Temp sensor is good what next
Double oven that lost power and will not reset and comes up with F o3
Hi and weclome to FixYa, I am Kelly
The oven temp sensor has failed. When the sensor fails the range control unit shuts off the oven. However..... this is a double oven an it should only shut off the oven with the bad temp sensor. If it got super hot...while you were using it and it themally protected itself you may also need a thermal fuse / high temp fuse. IF you can locate the model number and respond here, I will look your model up and see what may have happened.
(I tried to answer your chat but it had already been passed to another expert)
Thanks for choosing FixYa,
Kelly
Apr 20, 2011 | Whirlpool Microwave Ovens
My GE Profile electric oven keeps shutting off on me, it shows a "F3" code on the screen. What does this mean?
Sorry to read about your problem, I hope this helps you out.
your F3 means: Oven temperature sensor open you cannot reset this type of problem.
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Jan 02, 2011 | GE Profile JTP18 Electric Single Oven
F2 and F3 messages - shuts itself off. Any idea of what it is and how to fix it?
Hi
F2/F3 error message relates to the oven temperature sensor or thermostat faults.
The fix is normally to replace it.
This link may help if you want to do it yourself
www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Hope you get it fixed.
Dec 16, 2010 | GE JKP15 Electric Single Oven
Whirlpool error message EO-F3 and E4-F3 sometimes while cooking, when trying to use the clean oven mode (which will not even function), and sometimes when the timer goes off (inevitably shutting the oven...
Bad EOC. Have to change the oven control. Sorry but this will be the only repair unless you know some one who can take it apart and repair some connections by using a soldering iron. Good luck.
Feb 02, 2010 | Whirlpool Accubake RF362LXTS Electric...
My kitchen aid oven has error codes f3 e1 what do these mean, i can't use it , it keeps shutting off.
Hello there:
F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor
Now if it is just a f-3 and nothing else3 f 3
Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse
Jan 22, 2010 | KitchenAid Ovens
I have a Maytag Performa oven model pgr5710bdw. The Temp is all over the place, too high, too low and constantly changing. Cannot figure out what it will do next. I have already put in a new temp...
If you already changed your oven sensor, then your ERC or electronic range control is not reading your sensor correctly. You need to replace the ERC and its overlay. Not a cheap part. Also strongly recommend you buy a 2000 joule or higher surge protector to plug your range into, to prevent this problem from happening again. Good Luck, Appliance Specialists
Dec 22, 2009 | Ovens
Oven won't pre-heat
This is a failed oven temp sensor. the control is not receiving a proper resistance signal from this sensor at this time. the control will shut down the unit if this is the issue. check the oven temp sensors connections form the control to the sensor housing for loose or worn contacts, if the wiring is ok, replace the temp sensor.
Sep 24, 2009 | Ovens
I cannot get the oven to come on after I used the self cleaning.
Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
 Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
Electric oven. temperature problem
Change the temp sensor.
Feb 21, 2009 | Maytag Ovens
Thermador Pro Harmony PRD366EHU (Dual Fuel) Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
