Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
Holiday chest freezer 7.0 mod.lcm070 lc wires came off.
Need schematic to replace wires! Which came off during shipping.
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
I need a replacement door where can i order one?
From "Sears Parts Direct" on your computer.
When you search this name, it will ask you for your model number. Type that in, and you will see the freezer.
God bless your efforts.
Sep 10, 2015 | HOLIDAY 5 cu ft Chest Freezer White...
Is there a reset on a Holiday chest freezer
Check the thermostat, defrost timer and compressor overload one of them could have been damaged by the surge.
Oct 17, 2014 | HOLIDAY 5 cu ft Chest Freezer White...
Holiday chest freezer lcm070lc
There are only three wires, aren't there? One is a safety earth, probably green or green and yellow. It goes on the spade attached to the metal of the thermostat body. The other two are a live and switched live. They go on the two spades that come out the plastic body. If there happens to be a third, it will be an alarm signal wire. Connect in any order you like. If the compressor comes on and the signal light, all is well. If the signal light does not come on, and the compressor switches off at -12c swap 2 of them. If none of this happens, switch 2 of them.
Apr 21, 2014 | GE Freezers
My kenmore mod#2539183511 chest freezer comes on @30 sec goes off for @3-5 sec tries again.Need diag help or wiring diagram.
Sorry to read about your problem. you can have many different problems.
a wiring diagram will not help you in this case. all 3 items below at at the compressor.
odds are you will have to have the compressor replaced.
1. Failing compressor
2. Defective start cap
3. Defective overload protector
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Jan 02, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Trying to find parts for a Holiday brand chest freezer
Try on amazon, take a look here: Amazon com chest freezer parts. Wish you best of luck. Cheers
Dan
Feb 26, 2010 | Freezers
Maytag chest freezer mac1557aew does not get cold
This can be a number of things, one being a bad compressor/motor.
Does it run at all?
If not, the compressor needs to be looked at.
If you are handy, there may be a wiring schematic in the back to further troubleshoot.
You can trace the wiring from the thermostat to see if there is power at other components.
Feb 20, 2008 | Maytag 14.8 cu. ft. / 419 liter Chest...
Freezer not working, odd rythmic noise.
Is this the capacitor wires you are asking about perhaps?
Sep 08, 2006 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
146 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
