Question about John Deere Garden
Breaks stuck in park. parking break in up postion peddle will not release
  • 43 Answers
SOURCE: Parking break lights indication
check the level of the brake fluid in the master cylinder
Posted on Sep 29, 2008
SOURCE: Parking break light is always on (1994 Toyota Previa)
If you look where the parking brake arm is you should se a switch that it pushes against . The switch should be right above the parking brake arm .
Posted on Feb 23, 2009
mechanicm639
  • 253 Answers
SOURCE: Parking break light is on & Chimming When P. Break is released
On your parking brake assembly is a single wire switch. You can unplug it, but you will have to remember not to drive with it set. To replace the switch the whole assembly will have to come out. The switch is about $20 and labor should run about two hours. Good Luck
Posted on May 20, 2009
greg_margo
  • 1959 Answers
SOURCE: parking brake release
There should be a manual release. Reach up along the parking brake pedal. Ford has a manual lever that you pull toward yourself to release the parking brake. Hope this helps our with your problem. Best of luck.
Greg
Posted on May 30, 2009
  • 202 Answers
SOURCE: Cub cadet 2130 engine starts
there is a switch under the seat that senses if you are on the mower or not. check it, make sure it's plugged up try replacing it. if it does not "see" someone on the seat it will shut down
Posted on Jul 14, 2009
How do I release parking brake if the handle is broken?
If the parking break is your only problem. Try to grab hold of the cable or rod end that connected to the handle with a set of Pliers, or even better,Vice Grips and pull .
Jul 16, 2014 | 1999 Mercury Grand Marquis
No break lights wont come out of park
Do the brake lights come on when applying the brakes?
If so then the remote start could be causing the issues or the interlock may have gone bad
Feb 10, 2014 | 1996 Mercury Sable
Parking brake stuck on mercury villager 93
should be a nut some where on the hand break just losen this to release handbreak
Aug 24, 2012 | Cars & Trucks
1995 Olds cutlass supreme. Can't shift out of park. Couple of times before it did this but after fiddling around it released tiself and shifted. Today no luck.
Hi:
Ther is a small switch on the back side of your break peddle arm at the fire wall. an automatic transmission will not shift out of park whithout stepping on your break while shifting out of park. I would bet that switch is going out and that is what is causing your intermittant problem. shouldn't be too mutch to have it replaced. Good Luck...
Aug 08, 2011 | 1995 Oldsmobile Cutlass Supreme
Why does the parking break light stay on in my 97 Olds Cutlas Supreme. I have checked the level of the break fluid and it is full. I did have new break lines put in last year. I did have to slam on my...
Apply the parking brake with the vehicle parked, engine turned off and transmission in Park. Release the parking brake completely, then apply it again, and ensure that it is fully released. Turn the ignition on, check to see if the Parking brake warning light is on. If it is NOT on, apply the parking brake and check to see if the warning light comes on. If the light come ON wihen the Parking brake is applied,.....fully release the parking brake and check if the warning light goes OFF. If it does NOT go off, then an adjustment is needed at the parking brake switch.
Jan 09, 2011 | 1992 Oldsmobile Cutlass Supreme
Parking break stuck
disconnec the batt for a minute or do a scan for codes
Apr 19, 2010 | 1999 Chevrolet Silverado 2500
The parking break lever broke and now I cant take the parking break off to get the truck to a mechanic. Help.
Under the dash where the parking brake peddle at, if you look up under the dash, you will see a small lever, push down on the peddle and release with small lever.
Jan 08, 2010 | 2004 Chevrolet Silverado 1500 Crew Cab
Parking brake cable snapped but brake is on. any
Under the dash, where the break release handle is, you'll see a lever where the release cable is/was attached to. Either push forward, or pull back this lever and it will release the parking break. BE CAREFUL the foot peddle for the parking break doesn't hit you in the face!
Mine broke on the 2nd of this month as well....
Jan 02, 2010 | 2005 Chevrolet Suburban
Garden Logo
10 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
