Question about Toshiba 26AV502R 26 in. LCD HDTV
Reset parental code lock factory
How to reset or unlock child lock to toshiba lcd tv ??? & what code # for it???????
  • Toshiba Master
  • 3,320 Answers
Help unlock child lock on tv
You need to have child lock code! Maybe has factory default Look manual. Sometimes factory reset overides child lock. Not sure about your model though.
PLEASE COMMENT, I'M INTERSTED TO KNOW
May 06, 2015 | Panasonic TH-42PV8H 42 inch MultiSystem...
Unlock parent lock
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to get more, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 10, 2013 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Master password
May 31, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Child lock on in LC-T32HV
Feb 26, 2013 | Televison & Video
How do i disable the child lock
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
Sep 18, 2012 | Jensen TS2750J TV
Hi i have a samsung tv n im with bell but i forgot my password for parental control... help??!!
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Aug 31, 2012 | Samsung UA60D6600 60in. LED TV
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
Sanyo DP19649 LCD TV
If you cannot remember the password, this is not something I can help you with. Speak to Sanyo.
Sanyo AVL 278 Instruction Manual Turning Child Lock On Or Off Changing The...
Sep 02, 2017 | Sanyo DP19649 LCD TV
Parental code not working on sansui television
Instructions
Jun 27, 2012 | Sansui Televison & Video
Parental controls
wuts the model # on the television
Nov 03, 2007 | Insignia IS 20" TV040919 TV
Toshiba 26AV502R 26 in. LCD HDTV Logo
337 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
