Mywinlocker does not open partion of hard drive
Ok, here it is. I have "mywinlocker" and I am using it to partion out a part of the hard drive, encrypt it and hide the drive. The thing is when ever i put in my password the drive does not show up. I am not sure if i can just uninstall and so on. What is causing the problem and how the hell will fix it??
  • Kalle Foogle Ulusoy
    Kalle Foogle Ulusoy Apr 21, 2014
    And if i uninstall will all my files still be there?
  • 3,320 Answers
Posted on Apr 21, 2014
3 Suggested Answers
Hyarion
  • 74 Answers
SOURCE: Can't uninstall PC guardian
You can try Revo Uninstaller. It should be able to remove the program correctly which will allow you to re-install it.
http://www.revouninstaller.com/
There is a 30-day trial available on the website.
Posted on Apr 05, 2010
bronk50
  • 27725 Answers
SOURCE: can't uninstall mywinlocker
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. Hope this helps.
b>
Posted on Dec 17, 2012
I partitioned my hard drive into two partitions, now only one of my partitions mounts..what should i do?
right click my computer in the desktop click mange then click disk management you will see the partion rightclick the partion and click new partion follow the steps when the steps are over you will see the partion
Jan 29, 2011 | LaCie Rugged All-Terrain (301017) Hard...
I have hitatchi 60gb lap top sata drive.The partions disappeared
Ok if it has a start up failure or whats called a boot strap failure you can get your data off and still use the drive and maybe fix it by scandisk. You need a external hard drive enclosure cost about $15 up at Tiger direct, this works it has saved 3 hard drivers for me, I still use one as a external drive. It will not boot a computer but I store mp3's on it now.
Jan 23, 2010 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
No partion with new hard drive
Please continue to use the system as this does not in anyway disrupt its performances.
Good luck.
Dec 14, 2009 | Acer Extensa 5620 Notebook PC
I am having 8 gb transcend flash my flash was plugedin the usb of my computer. i was trying to use norton ghost for one hard disk.it was asking me for some option i dint see and started preesing ok ok .....
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 30, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
I can't make format, partions or install windows.
Hi shlmughni,
If you're trying to format this drive, and you have nothing on it you want, then I would suggest that you use a windows 98 boot disk HERE. And first thing you need to do is load dos by putting the floppy disk in your drive A: after you create it from that site of course. Then allow dos to boot up. I'd opt for the allow cd rom option when it asks. After you get a dos prompt A: type in fdisk. Go to the display partions section and see what your drive is partioned as? Once you find that out, I'd delete the partion from the main menu choice delete partion. After that create a new partion from the main menu. Creating a new Dos partion will allow you to choose the size of the partion you want, then after that it will create your new Dos partion. When that's done, exit fdisk, and go to the A: prompt and type in format c: This will format the drive all over again, and give you a clean fresh starting point in which you install your OS.
Good Luck
Mark
Jan 03, 2009 | Maxtor Hard Drive
Hard drive
http://support.microsoft.com/kb/313348
Apr 08, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
